Old 01-12-2009, 05:09 PM   #19
Split
Drives: 2008 Yaris Sedan
i'm still on a quest to find the lightest 16x7's that are at least +43mm offset. I've conluded that is the minimum to prevent rubbing with a 205mm width tire.
Split is offline   Reply With Quote
Old 01-12-2009, 05:10 PM   #20
well, if you didn't find it in this thread, I'm not sure you will -- lots of good choices posted here
Old 01-12-2009, 09:18 PM   #21
03Z33
03Z33's Avatar
Drives: TCR10
Racing Hart CP-035 are 12.8lbs each with valve stems in 17x7.0 +38, I doubt you'll find a stronger lighter wheel in this sizing.
03Z33 is offline   Reply With Quote
Old 01-15-2009, 12:03 PM   #22
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
light rims are mostlikely good only for tracks... slight bump or pot holes will easily damage them..
you're 100% right, weight is the only factor to look at regarding wheel strength.
15x7 +35mm RE30s weigh in at sub 10lbs.
Russelt3hPirate is offline   Reply With Quote
Old 01-15-2009, 12:14 PM   #23
I was looking into that too just now actually, can't touch those RacingHarts, or Volk CE-28s or TE-37's... SSR Type C's are quite light too!
www.wheelweights.net
Old 01-15-2009, 12:54 PM   #24
bosbik
in the toilet....
bosbik's Avatar
Drives: Vios
how about the Rota subzero's?..they are like the racingharts copy
here:
Rota Subzero Cast 15x6.5 12.9 lbs
Rota Subzero Cast 16x7 14.5 lbs
Rota Subzero Cast 17x7 16.5 lbs
Rota Subzero Cast 17x7.5 16.9 lbs
Rota Subzero Cast 18x7.5 19.0
bosbik is offline   Reply With Quote
Old 01-15-2009, 01:39 PM   #25
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I believe my Heliums are 10.8. It sweet having light wheels I just wish my falkens were lighter. The have to be the best lightweight wheel for the price and they can take it. I've ran over multiple holes and roadkill and the heliums are still standing.
bdc87 is offline   Reply With Quote
Old 01-15-2009, 07:13 PM   #26
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Price / Weight ratio, the Heliums win hands down.
Plus they look good on the Yaris. Very Vitzy looking
Old 01-17-2009, 04:40 AM   #27
phenoyz
phenoyz's Avatar
Drives: yaris
lightest 15
whats the lightest 15'rims?
phenoyz is offline   Reply With Quote
Old 01-17-2009, 05:37 AM   #28
03Z33
03Z33's Avatar
Drives: TCR10
Weld Racing make a drag racing wheel (for the rear only) that cannot be used on the street. It's 15x3.0" and weighs around 4lbs.
Old 01-19-2009, 09:58 AM   #29
Russelt3hPirate
l33t3st Asshole
width plays a huge roll in weight.
how wide are you looking to go.
although a 15 foot wheel seems excessive. ;)
Old 03-14-2009, 04:02 PM   #30
fuji
fuji's Avatar
Drives: Polar White Yaris HB
In you guys that have changed to significantly lighter wheels, how is the ride quality and the overall performance gains???
fuji is offline   Reply With Quote
Old 03-14-2009, 04:13 PM   #31
Ryu
Ride quality seems the same to me, but with better acceleration and braking that you will feel instantly.
Old 03-19-2009, 04:18 PM   #32
Split
i think the lightest low-budget to high-performance ratio would be rota slipstreams.
size: 17x8 or 17x7.5
bolt pattern: 4x100
offset: +48
they're lighter than factory and you can run up to a 215 width tire without rubbing because the offset is so high.
if you insist on rubbing a 16"inch for cheaper tires and lighter weight yet, you can get it in:
size: 16 x 7
bolt pattern: 4 x 100
offset: +45
and run a 205/50R16 instead.
They come in any finish you could imagine. I think Full Royal Black would be the nicest, but Full Royal Sport Bronze would look really hot on a white yaris too.
215/35R17 definitely wont rub, and 215/40R17 shouldn't rub and is closer to your OEM size. 215/45R17 would look sweet but would probably rub (i think that's the OEM size for my IS300).
Hankook & Yokohama make tires in this size: 215/35R17. The hankook tires only weigh 17lbs!
I ordered some Rota Circuit-10's for the yaris because that's what the girlfriend thinks looks best. I'll post pics of them when they're on the car, 16x7 -- Full Royal Gunmetal finish (brand new finish that was just released and no-one has yet)
Old 03-20-2009, 12:11 PM   #33
Mouse
Drives: 2007 MX5
949 racing 6UL's in 15x8 +36 offset weigh in at 12.7lbs. They also come in 15x9 +36 weigh in at 13.2lbs.
The 15x8 cost $159/wheel
The 15x9 cost $189/wheel
http://949racing.com/
Mouse is offline   Reply With Quote
Old 03-21-2009, 01:26 AM   #34
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Enkei RPF1 15x7: 9.9 lbs, $199. There's a few wheels that beat this, but they cost about twice as much.
Old 03-21-2009, 02:36 PM   #35
fuji
fuji's Avatar
I wonder if those 949 racing 6ul 15x8 would even fit on our cars. It would be really coll if they did.
Old 03-21-2009, 02:59 PM   #36
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i thought 16/50/205 on +40 offset on trd springs is ok.. im worried during camping.. the car is extra lowered rear tucked in.. would i rub while driving?? anyone!!
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 08:11 AM
FS: 17'' Motegi MR7 Rims and Khumo Tires Sabretooth Items for Sale by private party 11 07-02-2007 03:55 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 10:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 02:25 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 04:16 PM
