Old 02-16-2009, 12:45 PM   #19
SilverGlow
Drives: 2007 Yaris Hatchback
Originally Posted by 1stToyota View Post
Did Toyota issue an updated TSB? Their last one didn't recommend 0w-20 for the Yaris.
Yes, and over a year ago. Toyota issued a TSB which states one can use 20 weight oil in their 1.5L engines.
For the millionth time!
See attached official Toyota TSB, and you will see that the Yaris 1.5L engine can use 20 weight.
And yes, I've been using 0W-20 in my Yaris for the past 54,000 miles. Increase in MPG is just around 1% however. I use the light stuff so that it gets circulated quick during cold morning starts. Quick circulation means less wear and tear during the first start up. And it is during the first start up that 90% of engine wear happens. My engine does not consume any oil after 5,000 miles. The engine runs smooth and no strange sounds coming out of it either.
SilverGlow is offline   Reply With Quote
Old 02-16-2009, 01:14 PM   #20
1stToyota
1stToyota's Avatar
It states 5w-20 NOT 20 OR 0w-20
NO, you're drawing your own stupid conclusions again to alter their "5w-20" recommendation to fit into your straight 20 and 0w-20 needs for a southern Ca. climate condition that never needs 0w oil in the first place.
You don't need to worry about cold morning startups, you live in so. Ca. ...and film strength always plays a part in not wearing and tearing your internals. Not saying you'll blow your motor or make it drink oil, just saying that you're asking for trouble for using a viscosity that is NOT listed for the Yaris in the Toyota TSB...did you do a XD engine swap? Yes? Then that'd be okay...Yaris 1.5 still, not okay, according to the Toyota TSB that you like so much but can't comprehend.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-16-2009, 01:18 PM   #21
Tamago
Tamago's Avatar
Drives: UZJ100
i think you guys were all related to GW bush the way you fight over oil
lol
Old 02-16-2009, 01:22 PM   #22
1stToyota
1stToyota's Avatar
lol
I fight over what Toyota says is right for our motor...I don't like bad and maybe very costly advice being handed out.
2008 Scion xD
Old 02-16-2009, 01:24 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
nor do i..
but if 100 people on YW say that 0w20 is ok to run, then its fact.. don't bother opening that thing in your glove box (owners manual) YW says it, it's true!
Old 02-16-2009, 01:25 PM   #24
Yaribhini
I highly, highly suggest that one runs what the factory calls for in regards to viscosity and weight. Especially for those that have never owned a car that utilizes a timing chain configuration.
Yaribhini is offline   Reply With Quote
Old 02-16-2009, 01:44 PM   #25
1stToyota
1stToyota's Avatar
Which is 5w-30 (5w-20 recommendation added later), and that's what I use...1% over the 40+mpg that I already get isn't worth the risk of using a viscosity that isn't listed on the Toyota TSB...unless of course you're forced to quote only a part of the multi-viscosity rating to fool yourself into thinking it's okay to use the wrong oil
2008 Scion xD
Old 02-16-2009, 01:45 PM   #26
1stToyota
1stToyota's Avatar
nor do i..
Or bother looking at the oil cap
2008 Scion xD
Old 02-16-2009, 01:48 PM   #27
Tamago
Tamago's Avatar
Drives: UZJ100
WAIT, wait.. toyota puts information like that on the cap?
Old 02-16-2009, 02:04 PM   #28
yes, my oil cap says 5w30
Old 02-16-2009, 02:22 PM   #29
SilverGlow
ALL the oil brands that sell 0w-20 make the claim that that their oil is a great match for ANY 5w-20 application. AMSoil, Mobil1 and others make this claim.
And you are dead wrong about California and 0w weight oil. Anytime the ambient temperature is below 40F one will IN FACt benefit from 0w oil. You are also very foolish to think that it does not snow in California. It does in fact.
Film strength and viscosity have NOTHING to do with each other. And in fact, there are some 20 weights that provide film longer then heavier oils.
What you fail to understand is that 0w-20 and 5w-20 provide the SAME protection at full operational temperatures. The difference is during the first morning start of the cold day. And if a 5w is fine, then a 0w will be too. This is true according to AMSoil, and Mobil1 and ALL other makes that make 0W oils.
According to Toyota, 5w-20 can be used safely in a Yaris 1.5L engine. Now, that being true, one can ALSO use 0w-20, 0w-30 too for our Yaris engines, and this according to ALL the makers of 0w oils.
It is too bad you behave like you know more about oil then Toyota, AMSoil, and Mobil1.
Old 02-16-2009, 02:24 PM   #30
SilverGlow
..or bother reading TSB's, that are published AFTER Toyota printed their caps....
Old 02-16-2009, 02:34 PM   #31
The Shape
Drives: 2007 Yaris Sedan
So is four quarts of Castrol 5w-30 way to much?? I checked it and it is over the full line a little bit , but not drastically.
The Shape is offline   Reply With Quote
Old 02-16-2009, 03:11 PM   #32
1stToyota
1stToyota's Avatar
That say 5w-20 is for the Yaris, not 0w-20
2008 Scion xD
Old 02-16-2009, 03:35 PM   #33
1stToyota
1stToyota's Avatar
All but Toyota on Toyota's TSB. Funny that Toyota says 0w-20 is awesome for the Camry, but the Yaris needs 5w-20
Fool, 5w is winter weight, southern Ca doesn't need 0w, and the Yaris isn't supposed to use 0w-20, based on Toyota's TSB...it's the info that matters most to the Toyota dealership
The oil that most resembles K-1 kerosene propbably needs to get to the valve train and cam lobes quicker.
If that's true then Toyota wouldn't make a distinction between the two grades...shove what AMSOIL and what Mobil1 says about 0w-20 because it's NOT what Toyota says about 0w-20 for the Yaris motor (fact)
Yes.
Wrong. One can't say that about any Toyota TSB ever issued for the US Yaris 1.5L...not 0w-20, not 0w-30
5w-20 and 5w-30, and that's the way it'll be until you can fully quote, exactly, a multi-viscosity recommendation of 0w-30 or 0w-20 for the Yaris in a Toyota TSB
Show me where Toyota says that "0w-20" is okay to use in the 1.5 Yaris motor on the Toyota TSB...you can't include Toyota with AMSOIL and Mobil1 because they don't agree with Toyota. They list "0w-20" but Toyota TSB will not list "0w-20" for the Yaris 1.5...you drawing your own conclusions isn't good enough for me, I'll stick with Toyota TSB and owner's manual recommendations.
2008 Scion xD
Old 02-16-2009, 03:42 PM   #34
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
mine says TRD........
Old 02-16-2009, 03:44 PM   #35
Tamago
Tamago's Avatar
Drives: UZJ100
that must mean you can use Peanut butter instead of oil, since the cap doesn't designate specific oil weights!!
Old 02-16-2009, 04:20 PM   #36
BLAZINBLUEVITZ
i use oil from the mexican joint down the street. when i hit the block im smelling like bean burritos......
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
