Old 04-11-2009, 10:40 PM   #19
Wallyg
Drives: 3 door HB
I had the same thing. I had the dealer check it out since the car is under warrenty. They took care of it for free.
Wallyg is offline   Reply With Quote
Old 09-27-2009, 08:59 PM   #20
etech
Drives: 2007 - 3 Door Lift Back - Red
I had the same problem (tumbling rock sound when traveling approx <5 MPH)
I took rningonfumes's advice and found a small pebble inside the rotor. IF YOU EVER HAVE THIS PROBLEM and want to DYI ... a coat hanger and a flashlight will do the trick if you do not have the tools to take the rotor off. This takes patience!
etech is offline   Reply With Quote
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
