Old 03-10-2009, 03:21 PM   #19
Correct. The LCDs I inverted had a metal frame around them, so I was able to simply sandwich the ES film. If you go with a non-adhesive film and find that the LCD doesn't have a frame, you can simply tape the film around the edges, making sure that the tape doesn't extend past the frame coverage.
Old 03-10-2009, 03:39 PM   #20
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Much to contemplate now. haha
Old 03-10-2009, 03:46 PM   #21
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
My gas gauge is already inverted, from factory. Black background with white text.
I want to do my radio to match it. I have already done a white LED replacement on my radio (replaced the green LEDs). Currently the radio has a white background with black text, but would like the display to inverted. This way it would match my dashboard displays.
Meteorite_Marty is offline   Reply With Quote
Old 03-10-2009, 03:51 PM   #22
Meteorite_Marty
Originally Posted by Sodium Duck View Post
Or they're really big and cheap here.
http://www.3dlens.com/shop/polarizer.php
Which one did you order? Functionalitywise, are they all the same? It looks like they just differ by size and anti-glare.
Old 03-10-2009, 04:11 PM   #23
Sodium Duck
╚══════════RN
I'm just going to go with the Edmund Optics, but I'm not ordering until I go out and pop my gauge cluster out. I want exact measurements of the LCD before I go ordering something.
Like Scott said, some tape will hold it in place fine. I may even do a dab of some silicone adhesive in the corners for a more permanent thing.
Can you post pics of your dash? Are you talking about the black background and green horozontal gas gauge thing? Or I've seen another one that had more of a blue-ish background.
Old 03-10-2009, 06:04 PM   #24
Meteorite_Marty
Here are the pictures of my dash.
Old 03-10-2009, 06:24 PM   #25
Sodium Duck
╚══════════RN
Ahh yes, it has that blue-ish background.
I think you'll just have to buy an extra big sheet from Edmunds to cover it all.
Tommorow I'm going to pop my gauge cluster out, take measurements, and order from Edmunds. If I end up needing a bigger sheet, I'll sell the leftovers for cheap.
Old 03-10-2009, 06:25 PM   #26
Sodium Duck
╚══════════RN
Some of the ones there are not indicated for use by LCD screens. There are only a few listed that are intended for LCD's. Aside from that, they are based in Taiwain, and I don't like dealing over the seas.
Old 03-10-2009, 07:42 PM   #27
Meteorite_Marty
Well, I am happy with the dashboard. Its not as "blue" as it looks. Blends nicely into the dark for night driving.
I am going to try and do this for my radio display, to unify the look.
Old 03-11-2009, 12:50 PM   #28
Sodium Duck
╚══════════RN
So it looks like the visible area is about 1 7/8" X 3/4" and the actual LCD itself is about 2" X 1".
Hmm. I'm going to think about it for a couple hours then decide which film to buy. If I get the one from Edmunds, I could simply put the 2" X 2" sheet down and tape/glue the overhang above and below to the plastic case. Then the black face for the gauges would hold the rest down sufficiently I think.
Old 03-11-2009, 12:51 PM   #29
Sodium Duck
╚══════════RN
Forgot to add pics... boink.
Old 03-11-2009, 01:00 PM   #30
Snap some pics of the PCB with the microcontroller, etc. PK's been anxious for someone to post some when they have their combo meter assembly apart...
Old 03-11-2009, 01:16 PM   #31
Sodium Duck
╚══════════RN
... I just got back from putting it back in my car ... Dang!
When I take it apart again to do the film I'll take more pics. To be honest though, I think I'm going to do this mod without taking much apart. All you have to do to gain access to the LCD is pop the front plastic off the gauge cluster, pull the speedo needle (which I was too sissy to pull hard enough on to actually remove for these pics), and take the background off. The LCD is just sitting there. It snaps into place with those four little white indented tabs you see in the pics. Then there are 22 really long pins on the bottom of the LCD that go down to some connector.
Does he want pics of the whole circuit board taken apart, like the people who did the LED color changes to their gauge cluster?
Old 03-11-2009, 02:08 PM   #32
Sodium Duck
╚══════════RN
Good gravy.
NT43-781: $8.00
Subtotal: $8.00
Tax: $0.40
Shipping: $9.32
Total: $17.72
9 bucks to ship me a 2" X 2" piece of paper... I'm going to search around the net and see what else I can find. Even the stuff from Taiwan was only 4 bucks to ship, but they have a minimum $10 purchase thing. Still, it'd only be 14 bucks.
Old 03-11-2009, 04:13 PM   #33
Sodium Duck
╚══════════RN
Sounds cool. I'd like to have temp and MPG be enabled, that'd be snazzy. I'm just going to eat it big and buy from Edmunds anyways, so in a week or so when I take my gauges out, I'll do it.
It's really easy to take the gauge cluster out though, takes about 2 minutes total, just 2 screws. How come you haven't taken yours out?
Old 03-11-2009, 04:23 PM   #34
Sodium Duck
╚══════════RN
I'm assuming that the Canadian Yaris's have the same LCD gauge as the US Yaris's? Can you post a pic up of a gauge with the things you want turned on? I'm just curious.
In the above pics from Marty, you can see the things that the gauge can display, but isn't - if you look closely. I'd like to take a few shots of my LCD and see if I can see them too.
Just want to know what I'm trying to look for.
Old 03-11-2009, 06:13 PM   #35
neo1985
neo1985's Avatar
Drives: yaris hb s
Send a message via MSN to neo1985
Originally Posted by the_boss View Post
i have done that when in was in primary school with a calculator, i was able to take the lens in front of the lcd display and turn it (side facing lcd display goes outside and outside goes inside) and the color was inverted white digits and black background
not sure how the gas gauge is but would probably work too
BINGO!!! i was just about to say that.. u dont need to buy anything.. just take off the top layer carefully on the lcd and then turn it!!!
neo1985 is offline   Reply With Quote
Old 03-11-2009, 06:23 PM   #36
neo1985
neo1985's Avatar
Drives: yaris hb s
except when the sun hits it without the screen you won't see much , you need the screen to prevent washout
that true tho!! but thats how it is with that effect
