#1 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
@bailout
60 psi WILL increase tire wear and WILL decrease traction. end of story. I'm not arguing this one. Go find me one auto crosser who runs 60 psi on their yaris. and again, the tunnel vision of hypermiling is coming into play. What about all the added stress on suspension, suspension mounts, engine mounts, transmission mounts, interior trim pieces, pretty much the entire car??? I suppose the 20 dollars a year(again) you are saving will pay for all of that?? If you want the all important MPG, and that's ALL you are worried about, listen to every word bailout says. If you are interested in the total cost of something, I suggest doing your own research. |
#2 | ||
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
This is the fuel economy forum. For discussions on autocross please see the racing forum. If you can get any of the folks over there to test anything other than a butt dyno please let me know.
supmet, I'm not sure why you continue to hang out in the fuel economy forum as you don't seem to have much interest in it and you consistently deride the practices of those that do. You seem to thrive only on misinformation and alarmism and continue to do so in the face of mountains of data and practical examples that contradict you. Please feel free to frequent other parts of the forums that are more in line with your personality and personal desires.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#3 | ||||
Its pretty much elementary physics. You aren't absorbing as much energy with the tires = more energy gets transferred into the suspension and chassis. To completely write this off is irresponsible. Quote:
And I like getting better gas mileage. That's why I post here. I just like to get the WHOLE story - not the tunnel vision story that hypermilers THRIVE on. |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#5 |
Drives: 2008 Yaris Join Date: Oct 2008
Brian is especially correct about hypermilers having different needs from tires than the usual consumer. A tire which is inflated to 60psi is probably not safe for use at speeds over, let's say, sixty miles an hour. To the hypermiler such speeds are beyond the pale, and hence for them a higher pressure is safer.
Gene |
#6 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
here's a thought... go talk to the guys at the tire shops, see what they say about tires that are over or under inflated... ask them if it affects the mileage of the tires..
I have no intrest in what the local kids are doing and what they think work.. I want facts... I have yet to have my tire suppliers tell me to double my air pressure to increase my mileage... why? because what I save in a year running on over inflated tires i'll spend on tires the following year when these are pooched. tire pressure is very important... how do i know? I'm a mechanic (motorcycle) Sure most of my background is racing, bikes and offroad but tires are tires people. The number one cause of tire damage on motorcycles is caused by incorrect tire pressure, cupping and tire deformation is most common. I can't tell you how many times owners have come to me complaining of poor hadling or poor tire life...guess what...tire pressure is usually the cause or part of the cause. then there is the traction issue, with a motocycle even 2-3 psi cam make a HUGE difference. Usually not as noticable at slow speed when the foot print/contact patch is the largest and tire temps are cooler. The same applies to Auto tires though A tire at 60psi ..what is that at highway speeds when the air temps increase...its dangerous. if it were not for the steel belts in the tire holding it together it would likely explode when you hit a pot hole. Do you really think the tire remains the same shape at slow speeds as they do at highway speeds/ I enjoy the great fuel mileage, but come on... if it means that much to you go with a smaller set of 13" pie cutter tires like the geo/sprints had. BTW a simple tire tread depth gauge will easily show you what over inflating tires does as far as uneven wear.. you can't always see it just standing there with you arms folded staring at the tire sayin nope no wear yet! Most people never notice tire cupping or a shifting belt until they have a bald patch or the tire deforms and starts causing vibrations FWIW I followed the mileage group on the Ford focus forums... I had an 03 with 155km... I JUST got my second set of tires last fall at 120,000km. I ran 35psi The hypermilers on the same sight running even 44-50psi were getting 60-80k km to a set. figure that into the math... with the 1-2mpg less I may have got and what I saved using synthetics etc.. I bet it cost more buyin tires every 2 years for them.
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 05-03-2009 at 06:09 PM. |
#7 |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Strange, when I took my Cobra through the Bondurant school of high performance driving they REQUIRED that my tires be inflated to sidewall max. Not negotiable.
I have the stock Goodyears that Toyota puts on the 15" steelies. My three-door hatch is a hopeless, hapless disgusting pig in the corners with 32 psi in the tires. The TRD rear sway bar helped some, but running 51 psi front and 50 psi rear makes it dry corner like it's on rails. That's only six psi higher than sidewall max. These tires are wearing evenly so far as well. I'm not saying that any old tire can accomplish that though. Also, most of the pothole related tire failures I've seen were the result of the sidewall being pinched (crushed) between the road and the wheel. Higher tire pressures should make that harder to accomplish. Last edited by Rick; 05-03-2009 at 06:17 PM. Reason: Brainfart ..... wrong tire brand |
#8 |
i was under the impression you raise the pressure a bit so the sidewalls flex less under heavy cornering...im kinda surprised they put it at the max....but maybe the tires have a level of safety built into the "max pressure"?
#9 | |
If you're talking catastophic failures I could not say. If you're talking belts breaking, that's another topic. Don't know if higher pressures would help or not. I pays my money and takes my chances at factory pressure settings. |
#10 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
I think Obama is behind it all.....
#11 |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
#12 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Just an observation:
The TPWS in the Yaris seems to trigger somewhere down around 25 psi, and there doesn't seem to be any upper limit. (purely a limit warning system and not an active monitoring) Thus for myself, I am more concerned about letting them get too low, than running a few psi high. |
#13 |
I set it the way Toyota likes it; the way I like it
I think I'd rather be warned after losing 6 or 7 lbs vs losing 36 or 37 lbs (running 32psi instead of 60psi)
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 05-04-2009 at 02:26 PM. |
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
![]() I keep mine at 36 cold to increase sidewall stiffness (for cornering), and decrease wind movement. If you corner harder, the outer edges will wear the same as the centre. Each to his or her own, however. I set my car the way I like it, and fully hope everyone else does the same (i.e. how THEY like it, not how their friends tell them it should be) |
#15 | |
50 MPG or BUST!
Spoken like a true Rhode Islander! I doubt that any of the belligerents here will ever agree on this issue, or more importantly convince the other side. I recognize that both sides only want what is best for us fellow yaris drivers and want to share their info and educated opinions on the topic. But at the point where it shifts from a positive sharing of information and opinions to a negative, mudslinging argument (from whichever side it may be...) I second the solution of "to each his own." ![]() On a side note, I personally keep my OEM tires at or around 44 psi. As weird as it is, I prefer the comfort of 44 as opposed to 32, and that is why I keep it there. I have not noticed any uneven or untimely wear on my tires, although as someone mentioned previously, I am not measuring the wear scientifically. I have noticed a significant change/decrease in fuel economy the times my tires have been around 32psi, so I also second Bailout. (And that is my contribution to forming any kind of unscientific consensus.) |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
Seems like the police is on the side of having the tire wall max rating rather than the door jamb rating.
http://cardealerforums.com/alt-autos...rspective.html A good read. |
#17 |
For those who are lazy to click on the link (
)Maximum Tire pressure (a police perspective) We've talked here before about max cold tire inflation pressure. Here's a fascinating article from Officer.com . Some police officers drive with maximum air pressure in their tires as shown on the tire sidewall, not the door sill or the owner's manual. Here's a link to the article for some great photographs: http://www.officer.com/article/artic...on=19&id=27281 and here's the text in case the page is deleted in the future: Driving Under Pressure Proper Tire Pressure Could Save Your Life Posted: Wednesday, December 21, 2005 SGT. DAVE STORTON EVOC Contributor Officer.com How many officers check the tire pressure on their patrol car on a regular basis? We all seem to be great at checking that the lights and siren work, because the time to find out they don't work is not when you get a Code 3 call. Likewise, the time to find out your tire pressure is too low is not when you are in a pursuit and trying to take a corner at high speed. What is proper pressure? The proper tire pressure for the Police Crown Victoria is 44 psi. If you look on the sidewall of the tire, you will see that it lists 44 psi max pressure. Regardless of what vehicle you have, use the maximum pressure listed on the sidewall. Higher pressure results in better performance, decreased tire wear, and it lessens your chance of hydroplaning at a given speed. This number on the sidewall lists the maximum amount of pressure you should ever put in the tire under normal driving conditions. Pursuits and Code 3 responses are not normal driving conditions. Many agencies maintain tire pressure at 35 psi since this is what is listed in the owner's manual and on the door placard. The reason the owner's manual lists 35 psi is because we get the same manual as the civilian version of the Crown Victoria. The police version, however, is fully loaded with communications equipment, a cage, and your gear. You are not looking for a soft and cushy ride, you want performance. Myths about pressure Let^�s put to rest some common misconceptions. The tires will not balloon out creating a peak in the center portion of the tread when tire pressure is above 35 psi. There is a steel belt that prevents this from happening. Also, you are not overstressing the tire with higher pressure, and the tire will not be forced off the rim with higher pressure. The picture above is Bobby Ore of Bobby Ore Motorsports driving a Ford Ranger on two wheels. The tires on the left side have 100 psi in them, and they happen to be tires and rims from a 1999 Crown Victoria! This is a dramatic example of how pressure holds the tire in shape, and how much stress a tire can handle. Performance If you were able to watch a tire as it travels across the ground at high speed, you would see that it deflects to one side during cornering. The faster you are going through a corner, the more tire deflection you get. As the tire deflects over onto the sidewall, you get less traction and more of a tendency to understeer or oversteer. This could spell disaster when negotiating a corner at high speed during a pursuit or a Code 3 run. Higher pressure keeps the tire from deflecting onto the sidewall as much, which keeps more of the treaded portion on the road. A good demonstration for EVOC instructors is to have students drive a high-speed course in a vehicle with 32 to 35 psi. Then have them run the same course with 44 to 50 psi in the tires. The student will experience a marked difference in performance. Having officers experience this difference in vehicle performance is much more effective than just telling them to check their tire pressure. Hydroplaning When a tire rolls across a road covered with water, the tire tread channels water away so the rubber remains in contact with the road. The factors that affect hydroplaning are speed, and water depth. Conventional wisdom says that vehicles will hydroplane in as little as 1/16th of an inch of water. Not so coincidentally, legal tread depth is 1/16th of an inch. Tire manufactures and the Association of Law Enforcement Emergency Response Trainers International (ALERT) have shown that tires have more of a tendency to hydroplane when pressure is low. This happens because the tire footprint (the portion of the tire actually in contact with the road) is larger. For those of you who water ski, think of which is easier to get up on: a fat ski or a skinny ski. More tire surface in contact with the water makes it easier to hydroplane, just as it is easier to water ski on a fat ski. Also, a soft tire can be pushed in more by the pressure of the water on the center portion of the tread. This results in less rubber in contact with the road. Tire wear Much better tire wear results from maintaining proper pressure. Tires with lower pressure will wear off the outside of the tread faster from the deflection of the tire during cornering, and the tires will heat up more from increased road friction. This is one of the factors that caused the failure of a certain brand of tires on Ford Explorers some years ago. In 1999 the San Jose Police Department realized a significant cost savings by increasing the pressure in the training fleet to 50 psi. They soon followed up by increasing the pressure in the patrol fleet to 44 psi. For liability reasons, most agencies are reluctant to exceed the maximum pressure listed on the tire for actual patrol vehicles, but they reap the cost saving when going to 50 psi on training vehicles. Next time you inspect your vehicle, make sure you check your tire pressure since your ability to performance drive is significantly affected by it. You are not driving to the store to get a loaf of bread! You may be called upon to chase a dangerous criminal or respond to assist another officer in trouble. You don't wonder whether or not your gun is loaded before you hit the street; don't wonder whether your tire pressure is correct once the pursuit starts. Check your tires routinely, just as you do with all other critical equipment. -- Sgt. Dave Storton is the Director of the San Jose Police Academy, and he holds a Master's Degree in Adult Education. He is the lead instructor for the Emergency Vehicle Operations Course (EVOC) at the San Jose Police Academy, and is a lead instructor for the local regional academy. He teaches EVOC instructor courses, advanced EVOC instructor courses, off road EVOC, counter-terrorist / dignitary protection driving, and motion picture stunt driving. Dave has trained over 3,500 drivers. Photo courtesy of Bobby Ore Motorsports |
#18 |
Overall it seems that those who actually run with high tire pressures on their Yaris note that it works rather well while some who have no actual experience in the matter (haven't even tried it) are convinced it is wrong/false/dangerous/blahblahblah.
How can we expect to enhance our technical knowledge it we poison every thread that begins to challenge our existing understanding? Isn't just laying out facts and observations without including our "unconfirmed beliefs" and then letting the readers piece it together a more productive way? Who is going to come back here to "talk tech" when all they'll get for their trouble is a ration of shit?? |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| NEED USED TIRES!!! | natethegreat38 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-06-2008 12:11 AM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
