Old 05-04-2009, 02:11 AM   #19
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Good to know about DC not making anymore headers for us, Thanks Garm.
Old 05-04-2009, 04:16 PM   #20
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Thanks for the response. I added a quick video and pics to my first post. The video is really quick, but gives you an idea of what it sounded like. It was really loud over only 1.5k rpms :(. It was more like a farting noise like yarissedan mentioned. It was soooo much louder than the stock header. Not sure if you can get a good idea from that video.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-04-2009, 05:06 PM   #21
Deltasix
Deltasix's Avatar
Drives: '07 Liftback: Work in Progress
Send a message via AIM to Deltasix
I have the TRD Axle Back, so I have a good idea what its supposed to sound like.....
...and that sounds like crap!
"The basis of optimism is sheer terror."
Deltasix is offline   Reply With Quote
Old 05-04-2009, 05:19 PM   #22
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Your megan header should last a good long time - it's well-made.
DC Sports was acquired by another company and is not currently producing a header for the Yaris.
So it's impossible to get a DC?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-04-2009, 05:34 PM   #23
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You could maybe get a used one Good luck finding it.
Old 05-04-2009, 05:48 PM   #24
eii
Rides canyon walls
eii's Avatar
Yeah, this is a short video of only my TRD axel back for comparison
Youtube http://www.youtube.com/watch?v=fIG0OPV0Oog
Direct Link http://www.inimi.org/downloads/trdexhaust.avi
BTW in the header video the high rev at start up was because of the 1zz tb. I disconnected the battery while I was installing the headers so the ECU had to re-recognize the 1zz tb. The middle of the clip is when I put the car in drive, then park again, and then off (thank god ).
Old 05-04-2009, 06:10 PM   #25
jouna
jouna's Avatar
Drives: jdm yaris sedan
i don't know what's all the fuzz about this header cuz i said i had it and it sounds like a normal header and it haves noticeable gains maybe your header came faulty but mine works fine and its the same amk header
vvti bregao!
jouna is offline   Reply With Quote
Old 05-04-2009, 08:38 PM   #26
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Plug one end, fill it with water from the other end, spot where its leaking water, get it welded shut?
Oh and did you prise the bung off the stock header because you didn't mention doing that? Its a conical ring around the exit of the header, you need to bring that over to the new header.
Good luck!
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-04-2009, 09:00 PM   #27
PHXDEMON
PHXDEMON's Avatar
Yeah I think he has an axhaust leak somewhere
Old 05-05-2009, 02:33 AM   #28
MANSETH
KAVINT
Drives: KAVINT
Normally, when we change header, sensor will read different CO2 from new header. It could make the ECU calculate different O2 and CO2 for a while.
Means ECU malfunction, take your car for a one day drive then it should back to normal then depends on how good the header is. If your header was not leak.
MANSETH is offline   Reply With Quote
Old 05-05-2009, 03:09 AM   #29
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
probably poor workmanship on the header? to my knowledge, the welds
could be a LOT better.
808_Yaris is offline   Reply With Quote
Old 05-05-2009, 10:30 AM   #30
eric81
eric81's Avatar
Drives: Toyota Salesman
I have the same header on mine, and it is loud as hell. I noticed gains in power and in how fast my RPM's go up. Less resistance on the engine means it isn't working as hard to do the same stuff. Any header will make your car louder. The farting noise does sound like an issue though.
eric81 is offline   Reply With Quote
Old 05-05-2009, 11:32 AM   #31
eii
Rides canyon walls
eii's Avatar
I'll check for leaks later today.
Old 05-05-2009, 11:54 AM   #32
cleong
cleong's Avatar
Did you transfer the exhaust pipe gasket off the original header onto the header that you bought?
It looks like this:
(http://www.aeolus-online.com/catalog...pe_Gaskets.jpg)
TRD Blue brake pads
DC Sports header
Old 05-05-2009, 03:01 PM   #33
808_Yaris
Where is Oahu?
808_Yaris's Avatar
can't see the pic -_-
Old 05-05-2009, 04:18 PM   #34
Klinton
Klinton's Avatar
Drives: 2009 Yaris sedan Flint Mica
Nice
205/45/17 Nittos/ KN tyhoon 69 intake
EURO areo muffler / DF 210 Springs
NST 10% Pulley/ 15% tint
600watt rockford punch 12" subs and amp
micro image rocks!
Klinton is offline   Reply With Quote
Old 05-05-2009, 05:20 PM   #35
eii
Rides canyon walls
eii's Avatar
It looks like this:
OH FCK ME. I knew I forgot something. Is it easy to take the stock one off or should I just buy a new collector gasket/donut?
Old 05-05-2009, 06:16 PM   #36
808_Yaris
Where is Oahu?
808_Yaris's Avatar
it's easy to take it off the stock one
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
For Sale: Megan Racing Header yarisdarkness Items for Sale by private party 9 08-24-2007 03:31 PM
