Old 05-15-2009, 05:16 PM   #19
nemelek
DWEED
nemelek's Avatar
No dealer around here would disable an important safety feature like this. mikenacarato, are you sure?
Mine did.
Old 05-15-2009, 05:17 PM   #20
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by nemelek View Post
Mine did.
Mine too, after repeated attempts. But the ECU got reset and I need to do it again.
Old 05-15-2009, 06:04 PM   #21
gwasabi
Drives: 07 Blazing Blue LB
Thats what I told my GF when she first saw it. I said it's a ejection button that ejects annoying passengers when they piss me off hahaha
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-15-2009, 07:12 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
Interesting... Will that mess with the airbag deployment at all? The guy that sold me my car told me the airbags will not deploy if the passenger isn't wearing a belt. He said you are worse off if the airbag were to deploy that way. Probably
he's right. no seatbelt + airbag = broken neck.
with this setup, if someone's in the seat, and you've disable the seatbelt latch, the airbag will deploy and probably kill your passenger.
Old 05-15-2009, 07:36 PM   #23
gwasabi
This isn't for the passenger side. This is only for the driver's side due to my harness. MY passenger side is still there and the dealer WILL turn the chime off for the passenger side but not the warning light. That's what i was told
Serious Business...
Old 05-15-2009, 07:48 PM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
so put a resistor between pins 3 and 4 and you're set. resistors are about a buck at radio shack.
either way, if you're in an accident, you'll probably die anyway, with those brackets you got goin on lmfao
Old 05-15-2009, 07:52 PM   #25
gwasabi
Lifes no fun without dangers lol
I dunno if its 3 and 4 but its the red and green wire you can tap into and put a resister between them. I used a 2 ohm resister.
Serious Business...
Old 05-15-2009, 07:53 PM   #26
Tamago
Tamago's Avatar
Drives: UZJ100
and did it work?
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
Anyone find out how to turn off the seatbelt chime? overboost General Yaris / Vitz Discussion 54 11-22-2008 10:07 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
