Old 05-18-2009, 09:16 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by cdydjded View Post
I got it to work more than Richard, Cali Yaris &1 other person
the eManage would have been more money & the Tuner I use is trained & certified by AEM
yes I know it worked for 1NZ, Iv been in contact with him and also can by the EManage Kit he has directly from Greddy for $712.00
& the Greddy set up will be more $$$
what is cheap now will cost you more later
lmfao @ talking out of both sides of your mouth.
Old 05-18-2009, 10:29 PM   #20
cdydjded
Drives: Yaris LB Turbo
There is a difference between cheap (your turbo kit) & buying a product that cost less (AEM vs Emanage) that will give you the same results if not better
cdydjded is offline   Reply With Quote
Old 05-18-2009, 10:33 PM   #21
Tamago
Tamago's Avatar
Drives: UZJ100
agreed.
so why doesn't yours work?
Old 05-18-2009, 10:39 PM   #22
cdydjded
Once again reading skills, it works, I can adjust fuel & timimg, you want to meet up so I can show you? Be at the Toyota meet on the 24th, at Dave & Busters
Old 05-18-2009, 10:41 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
cool ok.
it works
but you have serious CEL issues and the car runs like shit.
Old 05-18-2009, 10:43 PM   #24
cdydjded
Once again, reading skills, you need to work on that, yes I have a CEL, the car runs fine, if you want Ill take you foar a ride on the 24th......
Old 05-18-2009, 10:57 PM   #25
Tamago
Tamago's Avatar
Drives: UZJ100
you're not modifying the signals, you're driving around with blank maps.
you might as well just install the jumper cable that came with the FIC
Old 05-19-2009, 06:54 AM   #26
1nz
Drives: Vios
did u use the yaris wiring diagram that is sent u? is it any help?
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 05-19-2009, 07:12 AM   #27
cdydjded
1NZ: I tried but I could not read what you sent, when you scan them they came out to small, if you could try to scan them again that would be great.
Old 08-03-2009, 06:27 AM   #28
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
any updates on this?
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 08-03-2009, 07:47 AM   #29
I just noticed this thanks to its bump. The primary 02 sensor is not a raw 0 to 1 volt output, like most 02 sensors (including the secondary on the Yaris). The primary output sits on a offset voltage from the ECM, so in order to tap into it your devices needs to be able to deal with the floated voltage and if your device uses the sensor data directly, and then fools the ECM with an output, its output needs to be able to deal with that offset.
Old 08-03-2009, 12:25 PM   #30
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Dumb question, but if you're just adding an offset voltage couldn't you wire in a regulator for the offset? If the output is something like 3-4 V, couldn't you just hook a regulated 3V source up in series with the FIC output to bring it up from 0-1 to 3-4?
bearda is offline   Reply With Quote
Old 08-03-2009, 12:54 PM   #31
The ECM is actually generating the offset voltage. If a FIC output gets connected in place of the OEM 02 sensor, then its output needs to be able to deal with the offset voltage.
Or, you could ignore the power pin going from the ECM to the sensor, feed the FIC output into a level shifter (using an op-amp) and into the ECM's input pin.
Old 08-03-2009, 01:07 PM   #32
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Update from Boomslang:
For the Yaris, we already have the connnectors and are waiting for the tooling. ETA Aug-17
Old 12-06-2009, 01:58 AM   #33
Brad D
Drives: 07 Yaris RS 3dr
Any word from Boomslang?
Brad D is offline   Reply With Quote
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
