#19 |
I'm a fan of the ATE Super Blue, not only due to its higher boiling temp., but also for the fact that it's really easy to tell (on the first fluid swap anyway!) when you've got all of the old fluid out.
They also make the same fluid in a more normal amber color, so you can get the color change benefit everytime. |
#20 |
![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
Old thread...
I flushed my system and put in DOT4 (as most 2010+ cars use this). However, I noticed after I was done that Toyota calls for DOT3. Will I have any problems? |
#21 |
There is one great big can of brake fkuid and all the manufacturers fill their little cans from it. So its all the same.
Same for oil! ![]() But DOT 4 is compatable with DOT 3 it just has a higher boiling point.
Synthetic Oil: Its All In Your Head |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
| Brake fluid info... | 06vitzRS | DIY / Maintenance / Service | 5 | 12-26-2008 12:05 AM |
| Engine dress up - brake fluid resivoire cap? | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 5 | 11-15-2008 07:59 AM |
