Old 09-20-2006, 09:40 AM   #19
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Originally Posted by 03Z33
sometimes it takes a 2 ohm resistor in-line...
will stop at RS on my way home tonight to pick some up...
when I started to do this I bought a pull switch so I can enable and disable the seatbelt sensor. Once i get it all figured out I will DIY for you all.
will work for parts
Old 09-20-2006, 12:33 PM   #20
Andrew Chalmers
Drives: NA
why not just keep the belt buckled on the empty seat?
Andrew Chalmers is offline   Reply With Quote
Old 09-20-2006, 06:29 PM   #21
FoEKuZ
FoEKuZ's Avatar
Send a message via Yahoo to FoEKuZ
this guys a GENIUS!!!
FoEKuZ is offline   Reply With Quote
Old 09-20-2006, 06:57 PM   #22
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
or at least there SHOULD be a bunch of headbanging on this one
tomjasz is offline   Reply With Quote
Old 09-20-2006, 08:32 PM   #23
vodkalush
I drive a yarrrris
vodkalush's Avatar
http://www.yarisworld.com/forums/showthread.php?t=1881
will work for parts
Old 09-20-2006, 10:30 PM   #24
mhero
Drives: Yaris 5Dr.
First of all, I haven't looked at my Yaris yet ... but for what
I've seen ... most seatbelt sign could easily turn off by unplugged
the wire under the seat. Have u guys try this?
Most cars in Thailand have one for driver seat .. I am not sure if
your cars do the same
mhero is offline   Reply With Quote
Old 09-20-2006, 11:25 PM   #25
DonnyRebel
1st Time Toyota Owner
DonnyRebel's Avatar
Drives: 2007 Meteorite Yaris Liftback
Angry the service mgr on duty gave me a bunch of bullsh*t......
but when I threatened to get the owner of the dealership involved, he called Toyota HQ in CA and verified that the chime could be eliminated (and how to do it). It took the tech about 5 minutes with the a normal scroll type scan tool to turn it off. I'll give you a hint......have your owner's manual handy when you ask. It states very clearly if you don't want the chime......
"See Dealer Technician to Disable"
"Success isn't permanent, and failure isn't fatal" - Mike Ditka
"Clown Car" - 07 3dr Yaris
"Redneck Roadster" - 04 Chevy SSR
"Wife's Ride" - 03 Honda Accord EX
DonnyRebel is offline   Reply With Quote
Old 09-21-2006, 06:57 AM   #26
vodkalush
I drive a yarrrris
vodkalush's Avatar
well whats the fun in doing that?
will work for parts
Old 09-21-2006, 02:24 PM   #27
Miceer
Drives: 07 yaris blazing blue 3 door
i was talking with my roomate about this today, my last vehicle she would never wear her seat belt and eachtime i noticed i would get made and make her put it on. we were wondering how much weight is needed to trigger the chime? i always put my bag on the passenger seat and thats never set it off, even when its been packed.
Miceer is offline   Reply With Quote
Old 09-21-2006, 02:30 PM   #28
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
My laptop in a targus backpack does it. 2 Gallons of milk do it. 2 pizza's do it.
ketel0ne is offline   Reply With Quote
Old 09-21-2006, 09:24 PM   #29
vodkalush
I drive a yarrrris
vodkalush's Avatar
my targus messanger bag set's it off as well; but when I'm working during the week I just been leaveing my passenger seatbelt "plugged in" like has been suggested as above
will work for parts
Old 09-22-2006, 09:49 AM   #30
MWill517
MWill517's Avatar
Drives: '07 Yaris Sedan Barcelona Red
If you dont want the seatbelt latched all the time (cosmetic reasons or whatever) Maybe you could get the seatbelt extender from your dealer, plug that in. Might look a little neater. Havent tried it. Worth a shot possibly. Seat belt chime isn't a problem for me.
MWill517 is offline   Reply With Quote
Old 05-10-2007, 10:00 PM   #31
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
it varies but usually around 60lbs. hondas systems set at 65lbs. but it also depends where the sensors are located in the cushion. some have multi sensors on each spring coil, others only have a few (front/rear), so you can have a heavy bag on the seat but if its not in the sensors range it wont sense it. oh and if there is a way to turn off the chime with the toyota scan tool, there is almost always a manual may to do it using an SCS connector to short the SRS system. maybe a willing toyota tech here can give us some info or a sequence to follow
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 05-10-2007, 10:18 PM   #32
vodkalush
I drive a yarrrris
vodkalush's Avatar
well... its alot less for the yaris... my laptop bag sets off the passenger seat. Thats 1 laptop (6months old), 3 hard drives, power adapter, and a bunch of CDs tops = 15pounds
will work for parts
Old 05-11-2007, 12:03 AM   #33
drifto
drifto's Avatar
mine isnt as sensitive. i think it depends if there are side airbags in the car. there is a second ecu that determins whether there is a child in the seat (79lbs or less its shown in the SRS section of the factory repair manual in the DIY section).which turns the curtian air bags off. if there arent any side airbags then it may just be a more sensitive,simple on/off sensor. id search more but im tired. theres also some specs on what resistance the ecu expects from certain components for anyone looking to jump the belt switch
07 Yaris LB 5spd
Old 05-11-2007, 08:16 AM   #34
vodkalush
I drive a yarrrris
vodkalush's Avatar
and if anyone doesnt want to deal with figuring it out, heres a link to the DIY ON/Off switch for seatbelt alarm : http://www.yarisworld.com/forums/showthread.php?t=1881
will work for parts
Old 05-11-2007, 08:19 AM   #35
grampi
Drives: Corolla
"Anyone find out how to turn off the seatbelt chime?"
Uh, just a wild guess here, fasten your seatbelt maybe?
grampi is offline   Reply With Quote
Old 05-11-2007, 08:49 PM   #36
drifto
drifto's Avatar
there has to be a manual sequence to disable it, there must be someone here who works at toyota that can find out.
btw i like your DIY vodkalush, id only be worried about any unwanted resistance in the srs system. the srs ecu sometimes measures resistance outputs in megohms, which doesnt leave much room for error when splicing and such. not for beginers i think, but an awesome setup nonetheless.
07 Yaris LB 5spd
Turn signal bulbs casterqc Cosmetic Modifications (Exterior/Interior) 2 07-15-2006 07:44 PM
Seatbelt warning annoyance! asa805 General Yaris / Vitz Discussion 5 06-30-2006 07:06 PM
