Old 06-18-2009, 08:43 PM   #1
vten
oh crap
use a good brand of tools such as craftsman or snap on for a start ... mine never had a problem like that before ...
I use the #2 for my bumpstop , I didn't even cut the rear one.....
Old 06-18-2009, 08:55 PM   #2
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
just messin around a lil bit with garm there...
but man...wow...
Old 06-18-2009, 09:06 PM   #3
Brian
Brian's Avatar
Do not cut your bump stops with the NF210s. I didn't cut mine and everything is perfect.
The drop isn't low enough to where you need to cut them.
Old 06-18-2009, 09:30 PM   #4
Taiyaki
アキバ製
Taiyaki's Avatar
^can someone confirm that?
well I got the strut bolt off, but my looks like I need to remove ther whole wiper to get to the final bolt...
Old 06-18-2009, 10:02 PM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
So anyone know yet for sure how much of the bump stop I need to cut for my NF springs?
Old 06-19-2009, 10:16 AM   #6
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
I don't know much about all this, but I do know one thing, and probably another too:
use better tools! haha
the white portion looks like polyurethane, you probably wouldn't be able to cut that cleanly at the suggested size, so they probably mentioned to go all the way down under it. I think keeping the poly might be a good thing, but idk. you can always take more off later
Old 06-19-2009, 11:06 AM   #7
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
you need more leverage, and spray the bolt with some penetrating oil.
I'd use a steel pipe on the end of your socket wrench to get more leverage, should be much easier.
BTW I used #2 for my bumpstop.
Old 06-19-2009, 11:29 AM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
has anyone replaced this without removing the top plastic piece and the wiper..
Old 06-19-2009, 12:15 PM   #9
^ yes, but you need an OFFSET box wrench to do it. If you use a power tool, you'll have to take all that apart.
Old 06-19-2009, 12:15 PM   #10
I'd probably go with Brian's advice and leave the bump stops as is. The NF really isn't an aggressive drop.
Old 06-19-2009, 02:08 PM   #11
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
use this type of wrench when loosening those bolts. if you need you can grab a pipe and slide it over the for more leverage.
aeipee13 is offline   Reply With Quote
Old 06-19-2009, 02:16 PM   #12
marcus
toyota
marcus's Avatar
you have to bend that for it to go in.... i decided to not switch the trd but still deciding to get the df210..
Old 06-19-2009, 06:34 PM   #13
toad
toad's Avatar
Drives: street-legal go-kart
for me, the key to the install was having the right tools. i purchased an offset box wrench from sears hardware(craftsman) for less than $20. it was 17mm on one side and 19mm on the other so i used that one tool most the time. also, i needed a 6mm allen key(the 'L' shaped kind - i had a multi-key style already, but couldn't get the angle to work right. any metric allen key set should have a 6mm in it, just be sure it's the 'L' style). for the df's i used part #2 only and the rest of the bumpstops are in my box with the stock springs. 1 week later, it rides great and looks killer! good luck.
toad is offline   Reply With Quote
Old 06-19-2009, 08:29 PM   #14
Taiyaki
アキバ製
Taiyaki's Avatar
Yeah I just cut them and used #2, everything is great. love the new look.
Old 06-20-2009, 01:41 AM   #15
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
told you!
hahaha
Old 11-07-2010, 05:19 PM   #16
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
How was the ride??
daddz07 is offline   Reply With Quote
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 04:49 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another name for bump stop? texkid Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-12-2009 11:33 PM
NF210s owners how much bump stop did you cut? derickveliz2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-26-2008 08:27 AM
Bump Stop kits now available.... Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-25-2007 12:51 AM
