Old 11-19-2008, 09:42 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
NF210s owners how much bump stop did you cut?
Thank you.
CLA 250, 4MATIC
Old 11-19-2008, 10:47 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
My NF's came with a diagram explaining how much you should cut. I just followed those directions and it came out great.
Old 11-19-2008, 11:01 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
nf is 1.2-1.5 inch drop supposedly cut should be 1.5 inch but you can get a way with 1 inch
Old 11-20-2008, 07:53 PM   #4
spookz
JDM yO!
Drives: '09 3dr. 5-spd
So, say if you are using NF's now with stock shocks and you cut the bump stops as directed. Will you need new bump stops if you change the shocks later on? Or do you reuse the cut bump stops?
Old 11-20-2008, 09:09 PM   #5
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I'm reusing. Or you could go all out and get the kit at FatCatMotorsports http://www.fatcatmotorsports.com/FCMstops_Yaris.htm
bdc87 is offline   Reply With Quote
Old 11-24-2008, 02:41 PM   #6
derickveliz2
Thank you so much for your help, I did!
CLA 250, 4MATIC
Old 11-25-2008, 09:35 PM   #7
spookz
JDM yO!
Now I'm no expert in the field unlike some of you on here, but I was speaking to a technician @ Whiteline (reputable suspension specialists in Australia), and I was advised that it would be okay to not cut the bump stops with spring drops of about 1.1"-1.5". That is unless you plan to drive your Yaris hard. Normal street driving would be okay without cutting.
(Having said the above, it heavily depends on the quality of the streets you drive around. If your roads are like the surface of the moon then by all means, cut them.)
I hope that helps.
Old 11-26-2008, 01:28 AM   #8
What's that?
Old 11-26-2008, 08:27 AM   #9
spookz
JDM yO!
What's that?
HAHA, well Garm.. I'd say it's "driving miss daisy" style
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 04:49 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
TRD Sportivo with Tanabe NF210's and cut bump stops? Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 07-16-2007 08:21 AM
Bump Stop kits now available.... Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-25-2007 12:51 AM
