Old 06-20-2009, 11:20 PM   #1
Originally Posted by yaris-me View Post
I'm confused. The hose from the PCV goes to the intake manifold after the throttle body and there is another hose that goes after the MAF. What is the point in having two? After throttle shut down wouldn't it just circulate air through the hose to the manifold?
vacuum sucks, simple as that. There is a difference in pressure on the ends of each hose, so the PCV system works as a kind of restricted bypass
Old 06-20-2009, 11:43 PM   #2
firebob
Drives: 09 yaris
There are 2 hoses.
#1 goes form the PCV valve that is screwed into the crank case to the intake.
#2 goes form the air intake to the crank case.
In the red box is #1. The black fitting is the PCV valve.
In the green box is where #2 should be. With a stock car this would only see clean air.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 06-20-2009, 11:47 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by firebob View Post
There are 2 hoses.
where did you get this information FORM?
Old 06-22-2009, 11:19 AM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
There are 2 hoses.
so does this mean we only need one filter which is on the red box.
Old 06-20-2009, 11:19 PM   #5
Ok sure.
But both hoses do not do the same thing.
The set up is to pull in air form before the throttle body through the crankcase and dump it back into the intake. The hose that dumps back into the intake has the check valve. When you let off the gas the throttle body closes down most of the way and the motor would suck air though the crank case and burn off the fumes in the crank case.
But with only one you will only get blow by and a bit of air from the change in the temp as the car heats up and cools down out of that hose. I didn’t see that you had removed the other hose.
+1, mine was originally set up like this too, on the atmospheric pressure hose, and never caught a drop of oil. It's gotta be on the vacuum hose connected to where your stock manifold used to be, as the vacuum in there (off-boost now, obviously) is what will suck the fumes through the system. Otherwise you're just filtering clean air.
Old 06-22-2009, 02:11 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
What is the inside diameter of the hose that you're connecting it to?
I might do the same, but need to know the inside diameter
Old 06-22-2009, 12:24 PM   #7
Morgan
Morgan's Avatar
Drives: 07 MM LB
I had a small length of 3/8" [I think that's the size it was] tubing I put on the filter then put the ventilation hose around that with a zip tie, there's a lot of stretch in that hose once you cut away the protective wrap. But the filter does have a very small inlet and outlet so instead of zip ties a screw clap might be an easier solution.
Old 06-22-2009, 12:45 PM   #8
marcus
toyota
marcus's Avatar
anyone confirmed the 5psi drop for using the filter is that affecting any hp at all..
Old 06-22-2009, 12:48 PM   #9
It should not, that PCV section is basically just a bypass, any air that is slowed down there will just go through the main intake tubing...
Old 06-22-2009, 12:52 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
vacuum is not measured in PSI
what psi drop are we talking about? i guess i should have read the rest of the thread.
Old 06-22-2009, 12:53 PM   #11
marcus
toyota
marcus's Avatar
ok thanks etimago..im on this.
psi drop due to oil filters.. which mean itll slow down the air going in the intake but as etimago said wont make a difference.
Old 06-22-2009, 12:58 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
psi drop where? where is the psi drop?
Old 06-22-2009, 01:02 PM   #13
marcus
toyota
marcus's Avatar
its says so on that specific filter when i went to homedepot/canadiantire to check it out right on the filter itself says it will have " 5 PSI " drop by using it.
Old 06-22-2009, 01:06 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
5psi drop at what air flow?
Old 06-22-2009, 01:08 PM   #15
marcus
toyota
marcus's Avatar
the excess air coming from the engine thats being recycled back to the intake. that air is whats being filtered due to oil that goes along with it.
i could be wrong though so check with the person that did this already im still in the process..
Old 06-22-2009, 01:59 PM   #16
marcus
toyota
marcus's Avatar
i guess that only apply for air compressors...so i guess it has no effect then..
Old 06-22-2009, 02:09 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
yup, you're in the clear! :)
Old 06-22-2009, 02:16 PM   #18
marcus
toyota
marcus's Avatar
ill pick it up this weekend..
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
OIL CATCH TANK increase performance? 33lam Performance Modifications 29 11-11-2008 01:08 PM
