Old 08-09-2009, 11:50 PM   #19
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i discovered that there are some visible signs of wear and tear to my crank and rod bearings after boosting the engine for about a year+.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 08-09-2009, 11:52 PM   #20
^ Any pictures? I'm sure there would be a lot of interest in seeing that.
Old 08-10-2009, 12:20 PM   #21
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Safely means: "You don't blow your engine when you are doing a WOT pass" It doesn't mean that it will last the same as if you let your engine stock.
If a STOCK Yaris engine was supposed to get 350,000 miles before a rebuild... a boosted Yaris will get there sooner.
How sooner? There is no straight answer. Depends on the maintenance, and mostly in how you drive your car.
Upgraded internals such as forged pistons and rods are not intended to increase longevity... Those are made to increase the engines ability to handle higher boost levels. Usually when you built an engine is because is going take some abuse... Longevity is not a major concern for people who spend the big bucks building an engine.
Realiability, longevity = STOCK
can't beat that.
Old 08-10-2009, 01:52 PM   #22
Penguin Garage
Penguin Garage's Avatar
After the initial break-in, I've been changing my tC oil every 3000 miles for normal driving, or after a few race days, or when it looks dirty, whichever comes first. I'm sure people do maintenance on differing schedules though. I know some more hardcore racers that do it after every race weekend.
blackstone oil analysis is a racers best friend, they'll be able to tell you almost everything about your engine.
some people do enough abuse to their oil after 1 weekend, some can go 3-4 weekends + daily driving before they "need" to change.
it really depends on the setup and oil analysis is a very cheap and good idea, especially if they have a baseline of your car pre-boost. :)
Originally Posted by battleversiontc View Post
oem boosted engines are built more solid and come with lower compression then n/a cars do. and also alot of research and development went into designing the motor and plus to they have alot of years behind them doing this and i mean alot. but upgrade the rods and pistons and change oil earlier then you normally would and run necessary gauges to monitor and dont beat the crap out it everyday and it will be reliable if tuned ight of course
lots of different variables when building a motor, assuming it'd put together right and it's tuned right you still will see less miles out of a built motor than you would a stock one.
good idea is to build it for 250 more horsepower then you plan to have. :)
Penguin Garage is offline   Reply With Quote
Old 08-10-2009, 02:40 PM   #23
So I should have built for 600 hp? ouch.
Old 08-10-2009, 07:49 PM   #24
changchewsoon
Drives: Vios Turbo
we discovered that when we took out the pistons for ceramic coating last round. i promise i will take pictures and post it up when we crack open the engine for rebuild. recently ordered toga bearings from IPP, will take some time for the shipment to reach Malaysia.
Old 02-05-2010, 12:51 AM   #25
changchewsoon
Drives: Vios Turbo
some pics of the bearings that i took now that the engine is out for rebuilt.
Old 02-05-2010, 08:46 AM   #26
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
hmmmm
Old 02-05-2010, 09:19 AM   #27
What to look for in these pictures? I'm no expert.
Old 02-05-2010, 10:43 AM   #28
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
There's some pitting there that shouldn't be.
Old 02-06-2010, 03:37 PM   #29
changchewsoon
Drives: Vios Turbo
was boosting 9 psi and yeah i do push the car very hard most of the time, often lingering at the red line limit.
well nevertheless the bearings would have to be replaced. hopefully the Toga bearings I purchased from IPP will perform.
i wasn't able to locate a part number for our 1NZ from ACL and Clevite. if anyone here manages to do so appreciate if you could share.
alright, i'll try to snap pictures of the crank as well, was thinking to keep the stock crank pulley though.
TC swap? MicroHB Performance Modifications 38 03-26-2009 12:39 AM
Induction with an Auto-Trans. Sweet Mercury Forced Induction Forum 7 09-08-2007 03:15 PM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
