| View Poll Results: When did you experience your first mechanical failure? | |||
| None yet! Though few miles... |
13 | 22.81% |
| None yet! > 20k miles |
21 | 36.84% |
| None yet! > 50k miles |
14 | 24.56% |
| None yet! > 100k miles |
0 | 0% |
| < 20k miles |
6 | 10.53% |
| < 50k miles |
2 | 3.51% |
| < 75k miles |
1 | 1.75% |
| < 100k miles |
0 | 0% |
| < 150k miles |
0 | 0% |
| < 200k miles |
0 | 0% |
| Voters: 57. You may not vote on this poll | |||
Thread Tools | Display Modes |
#19 |
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
Scary. I hate to see how much that will cost to fix. What is that red V thing? TRD?
#20 |
Been a long time messing with cars.. |
#21 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
$1200's getting off cheap for a thrown rod these days.
#22 |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
7 out of the 43 votes had mechanical failure before 50k miles? not good. i hope many of those were self induced.
#23 |
Beast
dont worry.. if you drive your car like a jolly ol green peace lover and on top of the maintenance, you shouldnt see any problems
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#24 |
that was a complete engine with all accessories (except AC compressor) and a transmission attached.
the odometer on the car it came out of showed 2,985 miles ![]() i got really lucky. http://www.gardnerautoparts.com/
#25 |
It's silly to think that a poll on a forum like this tells you anything meaningful about the reliability of the car. It's self-reported, and people who've had a problem are the ones most likely to reply. And we're a small segment of Yaris freaks anyway. You'll have to look at the larger surveys like J.D. Power, Toyota's, etc. for any sort of meaningful numbers.
#26 | |
also held its value better than almost any car in its segment. 3 years after purchase (for $12,500) a pristine xA with my mileage could still retail for $11,200. try finding any other car that held it's value that well
#27 |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
No mechanical problems, although the rear defroster had one line that wasn't working and I had the dash rattle. I don't really count those as mechanical failure.
#28 | |
what skews it is that a disproportionate percentage of YW members modify their cars vs the general population of yaris owners, since im certain 99+% of them never give any thought to modifications. |
#29 |
over 22k in my '07 and nothing yet /knocks on wood...
#30 |
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
Right front wheel bearing went at approximately 8000km/5000miles.
#31 |
do you have aftermarket wheels?
#32 |
![]() ![]() ![]() Drives: Black '09 2dr HB Join Date: Feb 2009
does a flat tire count lol? About to hit 4,000 miles and am getting the low tire pressure signal =( I got it a few days ago, filled the tire with air, was ok for a day, now its back! Guessing there must be a hole.
#33 |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
low pressure signal? wow. Really? Didn't know the Yaris could do that.
#34 |
Yea, the one that looks like (!) manual says "Indicates low tire inflation pressure" that basically means "indicates flat tire" right?
The thing is, none of the tires look flat. There's no bulging at the bottom. But when we tested them the first time, one did have a significantly lower pressure so I don't think the light is malfunctioning... but like I said, nothing looks flat. Going to a mechanic today that can hopefully find and patch a hole, I don't want to buy a new tire! |
#35 |
That signal looks like a "moon" smiley.
It goes off when the tire pressure gets down to about 25 PSI, which doesn't look "flat" but is certainly too low. Our basic TPMS system doesn't tell you which tire is down, just that one or more is, and it doesn't affect it when the tires are rotated. |
#36 |
| Yaris 2001 - serious problem | adnanmalik | General Yaris / Vitz Discussion | 10 | 06-19-2006 08:59 AM |
