Old 11-27-2009, 08:35 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You did dilute the coolant to 50/50 with water i hope as straight coolant does not work well,the way to get air bubbles out of the cooling system is to burp the radiator which involves running the car with radiator cap removed for about 20 minutes or until you see the thermostat open and the water starts rushing around the system,replace rad cap at this point and you wont have any air in the system.
Old 11-27-2009, 03:22 PM   #2
PatrickJohnson
Drives: 2008 Yaris LB
you need to fill the overflow. there is a line on the side of the overflow tank that indicates where the levels should be both with the engine hot and with the engine cold. It needs to be filled to that level.
PatrickJohnson is offline   Reply With Quote
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 12:40 AM
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 02:50 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
