Old 11-08-2009, 08:49 PM   #19
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Originally Posted by chongopants View Post
so if I am going for SM, with a pretty much stock car I am gonna get PWN'ed right? B/C that is what I would have to do.
Yes, you will get owned, and then some. At the same time, you can run in a "tire" class and probably be somewhat competitive. Honestly, until you get some experience in autox, it really won't matter what class you are in.
Also, many clubs have a "novice" class where you can drive any type of car and be indexed against the other novices based on your car class, but everyone is a novice. Great class for experience and not getting owned by experienced drivers, who can probably outdrive most newbies in a Yugo. :)
I just completed a season in novice, and I'm glad I did. If you really decide you are a killer driver and want to compete in Autox beyond the local events, then worry about getting your car/class worked-out to be competitive.
Old 11-08-2009, 08:52 PM   #20
Morgan
Morgan's Avatar
Drives: 07 MM LB
....but yes removing the backseat does put you in SM.
If you're in SM, add a supercharger/turbo and some slicks! It will be way fun - I'll sell you mine cheap!
Old 11-09-2009, 08:02 PM   #21
Jason@SportsCar
Just a few updates... As of 1-1-09 the STX wheel and tire allowances were changed for 2wd cars. 9" wide wheels and up to 265mm tires. Also the STU tire width was increased for 2wd, to 285mm.
Then there is the obvious item missing, cat-back exhaust is legal in all classes.
Oh, and for you STX/U guys... Don't rush out and buy a clutch and flywheel based on this list. Not legal.
mspaint to the rescue
Old 11-15-2009, 11:45 PM   #22
echosqwat
echosqwat's Avatar
Drives: Porsche Boxster
While Yaris isnt much of an AX platform how about FSP? I think that would be decent class for well sorted Yaris - probably out gunned in HP but weight is decent. SM would be tough class in Yaris unless your went all out with 250 + HP turbo motor and lots of suspension work and huge slicks.
Its too bad Toyota doesnt offer a sports suspension package on this car. Little stiffer/lower spring the Yaris would be decent in Stock class due to its low weight.
echosqwat is offline   Reply With Quote
SCCA Texas Motor Speedway Road course 9/27/09 ozmdd Tracking, Racing, Auto-X Forum 3 09-28-2009 01:13 PM
Benefits of SCCA rstb88 Tracking, Racing, Auto-X Forum 8 12-01-2008 02:43 PM
SCCA Auto X Event nqd New England 16 09-09-2007 12:01 PM
Yaris classing eclip5e Tracking, Racing, Auto-X Forum 11 12-23-2006 01:46 PM
