#1 |
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
One thought would be to do some generic dynomat along the center tunnel and especially in the spare tire well, which is totally uninsulated. Might cut that drone down significantly. Also, much cheaper than exhaust work.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
As I'm unfamiliar with dynamat, how much would that cost? Should I pull the seats and carpet, then insulate the whole thing? Or just the back end, since that's where the noise is coming from?
#3 |
do the rear first, it will make a difference. And there are other products out there that are less expensive than Dynamat and seem to work about as well. Check the Audio section on here for those threads.
#4 |
Just for fun, before school this morning, I stuffed a pillow and some blankets in the tire well and things calmed down significantly.
#5 |
there ya go
#6 |
![]() ![]() Drives: stock Join Date: Apr 2009
I plan to install a custom make header for my yaris but still not sure few item.
what is the most ideal size for 4-2-1 header setup? Example size for 4-2 & 2-1 tube size and best length to built? for the 4-2-1 final 1 out if use 2" tube will it be too big for our little 1nz-fe to push? |
#7 | |
#8 |
Noted, will use 2" tube. what about the tube size from 4-2 should be and the length needed?
#9 |
Again, I wouldn't know as I never built a header. I'd take a look at an aftermarket one like the DC Sports header and maybe model yours after that one. There isn't a whole lot of room because the exhaust is on the backside of the motor and is very short.
#10 |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
When I had my custom exhaust done for myself, the guy at the shop decided that since I said I wanted a more performance oriented exhaust he'd just slap on a straight 2'' pipe and run it out the end, sounded fine on the outside, but I got inside and drove it for 10 mins and it killed me. Fortunatley, that was just him testing the waters for me, since a straight pipe is the most performance minded, and I went ahead and had him install my flowmaster 60 series in, and then it was like heaven. It roared at WOT, but you couldn't even tell I altered it at cruising rpms.
Without a muffler, it's going to kill you, and without a resonater, it's going to sound raspy... My exhaust was done resonater back, so as to avoid the raspyness. Good luck with noise though |
#11 |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
I had a custom exhaust done about a month ago now. Replaced the stock muffler with an Imco model. It went in the place of the original resonator (almost exactly the same size and shape so it fit very well), then a new Imco resonator went between the rear axle and the dual, rectangular tips (center exit). So essentially the muffler and resonator swapped locations. I ran it like this for two weeks and decided it was too loud, especially inside. I also debated about doing some sound deadening material in the trunk, but decided to take it back and add in a second Imco resonator. The shop was able to put it right after the muffler and it is also a straight through design, just like the first one. This reduced the sound again by about 1/2. Just perfect for me! I may still do some sound deadening in the trunk, but no longer because of the exhaust, more from how there is no insulation back there at all! Hopefully for you the sound deadening will make it sound just right.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#12 | |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Apr 2009
#13 | |
Let me know when you have a date and time and I'll try to stop by.
#14 | |
Once it's done and if you find you need it tweaked one way or the other, they will be happy to do it! They want you 100% satisfied. Heck, exactly the way it should be!
#15 | |
#16 | |
AD&D Dork
Drives: 07Liftback/07sedanS Join Date: Oct 2008
![]() Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint. Last edited by GnomeBody; 05-13-2010 at 01:35 PM. |
#17 |
![]() ![]() ![]() Drives: 08 Yaris Join Date: Oct 2008
so much useful information in this thread...love it lol
RIP Yaris, I will miss your superb handling a lot. darkmoon87's picture thread http://www.yarisworld.com/forums/showthread.php?t=10013 |
#18 | |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
| Custom 1.75" catback exhaust - worth it?? | fuji | Performance Modifications | 4 | 05-09-2009 06:46 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Custom exhaust or pre-made exhaust - which one makes more power? | fuji | Performance Modifications | 9 | 03-08-2009 12:24 AM |
| Custom Cat-Back exhaust Yaris TS | CASTREX | Yaris TS Talk | 16 | 10-24-2008 12:56 PM |
| How much has your custom exhaust cost you? | whooppee777 | Performance Modifications | 7 | 07-21-2007 11:20 AM |
