Old 01-29-2010, 10:59 PM   #19
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
Originally Posted by TOUGEghost View Post
So it's like you gave yourself a whole bunch of vacuum leaks with all the unmetered air from the butt dyno tuned "auxiliary air intake" system. Although I really can't see much air actually getting through all those tiny little tubes, filters, and valves anyway.
don't worry, a lot of people don't believe it either, but once you have tried it, then it is a completely different story
sujonol78 is offline   Reply With Quote
Old 01-29-2010, 11:02 PM   #20
d1nzfe
Drives: 1NZ-FE
nice dyno machine u have in indo. But i dont wish to run on that dyno ever!
d1nzfe is offline   Reply With Quote
Old 01-29-2010, 11:14 PM   #21
sujonol78
Drives: 1nz-fe / MT
it's not the dyno's fault it is just a different way of tuning.
Old 01-29-2010, 11:15 PM   #22
d1nzfe
Drives: 1NZ-FE
your tuner should travel the world and be famous then.
Old 01-29-2010, 11:25 PM   #23
sujonol78
Drives: 1nz-fe / MT
if you have a chance to come to jakarta, i will introduce him to you
Old 01-30-2010, 12:19 AM   #24
the reason i'm keeping with stock rods is because I don't want to sacrifice the lower end power band
How are rods related to power output, except that forged ones don't break as easily?
Old 01-30-2010, 02:42 AM   #25
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 01-30-2010, 01:20 PM   #26
07 Toyota Yaris 310hp
Old 01-30-2010, 11:14 PM   #27
d1nzfe
Drives: 1NZ-FE
omg we are pushing up his topic popularity!
Old 01-30-2010, 11:27 PM   #28
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
getting 132 with those mods is not done by simply tunning lol. theres more to it than that.
Old 01-31-2010, 12:24 AM   #29
supmet
Drives: 2007 4 Door Yaris
I like all the disbelief from people in the US where we can't do shit with our ECU, and its well known in asia they can tune the stock ECU.
Maybe as a community we could try to learn something and improve the yaris, instead of talking crap to the new guy
If he said he was from puerto rico and used duct tape and pvc you guys would believe him huh?
Old 01-31-2010, 07:34 AM   #30
06silveryaris
Drives: 2006 yaris
thats true +1
06silveryaris is offline   Reply With Quote
Old 01-31-2010, 07:49 PM   #31
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
With all the air that's getting in without being metered by the maf, which I assume you are compensating for with the Neo, what afr do you run under full load?
And if the throttle body is such a restriction, why not just upgrade it instead of doing the above?
rob323 is offline   Reply With Quote
Old 01-31-2010, 08:09 PM   #32
Asking questions is not talking crap, just for the record. And there are a few more or less experienced tuners on here that absolutely do not get what he is doing or why. That IS trying to learn.
Old 02-01-2010, 01:18 AM   #33
sujonol78
Drives: 1nz-fe / MT
So it's like you gave yourself a whole bunch of vacuum leaks with all the unmetered air from the butt dyno tuned "auxiliary air intake" system, although I really can't see much air actually getting through all those tiny little tubes, filters, and valves anyway.
You're claiming you got about 23hp from an AFC, air filter, and a muffler?
yes
Old 02-01-2010, 01:53 AM   #34
sujonol78
Drives: 1nz-fe / MT
i respect all the things you've done to increase the performance of your engine, i even learn something good from this forum. i never said it is a mistake, i never said that the things i did with my engine is the only "right" way. please understand the difference between tuning and modifying ( or even "replacing" ). yes, the stock engine holds a great potential without having to modify or replacing it with performance parts, so that's why we ( my tuner and i ) are exploring the hidden potentials, and i have shown you the results without any exaggerations or lies.
the same dispute also occurs in my country, so no harm done.
now you know there are "unconventional" ways to explore the hidden potentials with, if i may say, a more efficient way.
PS: I'm not from Puerto Rico, I haven't done anything to the stock ECU, and the PCV valves really works, and I don't care for popularity.
Old 02-01-2010, 03:52 AM   #35
sujonol78
Drives: 1nz-fe / MT
the reason i'm keeping the stock con-rod is because the terrain that i use is uphill - downhill type, that's why i need torque not top speed. if i change the con-rod i have to change the camshaft as well.
Old 02-01-2010, 11:23 AM   #36
no, forged rods are the same exact specifications as stock ones, in terms of shape and function. I have forged rods with stock camshafts and stock crankshaft.
Changing the rods simply does not change the power output of the motor.
Anybody in the Phoenix Area want to have a get together? kustom play Southwest 12 09-13-2009 11:52 PM
FS: Micro Image 1NZ Engine Cover (Black) Treyz Items for Sale by private party 10 06-13-2009 01:04 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
Ask The Phoenix The Phoenix Off-topic / Other Cars / Everything else Discussions 25 09-06-2007 09:24 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
