Old 03-06-2010, 02:58 PM   #19
An even more relevant question:
there are two kinds of "stuck". 1, when the pedal stays physically depressed without your foot on it, and 2, an electronic malfunction that results in signal still being sent to the throttle.
Which kind of stuck is this?
cali yaris is offline
Old 03-06-2010, 03:01 PM   #20
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Loren View Post
Nobody has asked the most relevant question: Was the engine warmed up or was it cold? What was the ambient temperature?
The Yaris idles pretty high when it's cold, and the computer does funny things sometimes when you're on/off throttle, especially when it's cold.
Stuck means stuck. If you take your foot off the gas and put the clutch in or the transmission in neutral and the engine continues to race, THEN it's stuck.
that was what I was thinking...
talnlnky is offline
Old 03-06-2010, 03:06 PM   #21
Snappy
Drives: 2 Yaris Hatchbacks
This thread made me finally search for info about the pedals and the purported "fix." I found these interesting threads (with pix:)
http://www.thetruthaboutcars.com/exc...ta-gas-pedals/
http://www.thetruthaboutcars.com/toy...lusive-photos/
http://www.thetruthaboutcars.com/why...r-denso-pedal/
Both my 2007 yaris hatches have Denso pedals.
Snappy is offline
Old 03-06-2010, 04:04 PM   #22
PaddyMac
PaddyMac's Avatar
Drives: 09 Yaris
Sounds like a TROLL.
Looks like a TROLL
Smells like a TROLL
it must be a troll
let us not feed the troll
PaddyMac is offline
Old 03-06-2010, 04:12 PM   #23
^ OP has been around longer than you have
WeeYari is offline
Old 03-06-2010, 04:16 PM   #24
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
I am not a troll, I have been on here before and shared my experiences with my Yaris. This pedal issue is serious and very real. To answer your questions, my car had been running for awhile, so the engine temp was probably not cold. I had no mat there, and the pedal stuck but released as i stepped on the brakes hard. I was doing a constant 15 mph in my neighborhood.
Twistoffate0817 is offline
Old 03-06-2010, 04:20 PM   #25
Twistoffate0817
And no, I do not have cruise control. I do not even have power windows or anything. Just a base model with a radio.
Old 03-06-2010, 05:03 PM   #26
advocate
Drives: car
Originally Posted by CtrlAltDefeat View Post
err unless I'm missing something, pressing the clutch in should make it easy to put it into neutral on a manual...
correct. what he means though is that at high RPMs the Yaris doesn't like to get out of gear, even in a manual. and the car would certainly be at high RPM if the accelerator was stuck.
it's the stock transmission oil, it could be a bit better.
advocate is offline
Old 03-06-2010, 05:14 PM   #27
krusty
krusty's Avatar
Drives: 2010 Yaris ce
have you done any mods to your car?
krusty is offline
Old 03-06-2010, 05:23 PM   #28
127.0.0.1
hey don't ask us to diagnose this.
take it to a dealer. no one will be able to give
an simdgen of actual good advice unless they look at it in person
take it to the dealer and don't get killed doing so
127.0.0.1 is offline
Old 03-06-2010, 05:48 PM   #29
Twistoffate0817
The only mod i have performed is an "eco meter" that tracks how many MPG I have.
And yes I know, I just wanted to see if anyone else has had a problem with their pedals and to inform everyone here that it has happened.
Old 03-06-2010, 06:32 PM   #30
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
no issues with my 07 manual
it kept going as in it kept speeding up?
http://www.4055design.com
kustom play is offline
Old 03-06-2010, 06:50 PM   #31
TheSilkySmooth
TheSilkySmooth's Avatar
If yaris has any problem ist the noisy voltage rectification causing loss of power when a big electrical load is on. Thats the issue with my car. My throttle has never acted up - unless I made it stick to the floor with Ye ole' leadish foote.
TheSilkySmooth is offline
Old 03-06-2010, 07:24 PM   #32
Kal-El
Kal-El's Avatar
And has 12.5 times as many posts.
People need to inform themselves before they post such accusations.
Kal-El is offline
Old 03-06-2010, 07:33 PM   #33
JBougie
JBougie's Avatar
Please keep us posted - I have never had a problem with my 07. Do you have the Denso pedals also?
It may be nothing, but I know I'd be at Toyota asap also to check it out.
JBougie is offline
Old 03-06-2010, 07:34 PM   #34
Kal-El
Kal-El's Avatar
Originally Posted by Twistoffate0817 View Post
What the heck! I was doing 15 mph and took my foot off accelerator pedal and it kept going! I had to press hard on my brakes and it dislodged itself.
Couple of observations...
Doesn't the car roll at about 15 mph at normal idle with foot of the gas? Nearly all AT cars do this. Only some German cars with excessive engine braking move along slower.
And at 15 mph, would it really call for jamming on the brake? I can't really see how it would be possible for the brakes to not respond under normal stooping pressure at a crawling speed of 15 mph.
Not to doubt your situation, but it doesn't seem to add up.
Kal-El is offline
Old 03-06-2010, 07:53 PM   #35
Hershey
see if the TOYO dealer where you purchased the car is willing to pick it up at your residence on a flatbed at TOYOTA's expense . We just traded in the 2009 automatic 5 door for a 2010 automatic 3 door . Please keep us informed of your plight . Best of luck .
Hershey is offline
Old 03-06-2010, 07:55 PM   #36
Hershey
I too believe in T.O.F.s' words . Everyone's so quick to judge . TOYOTA is no saint . Like many big corporations . Money is the bottom line .
Hershey is offline
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Dead pedal? RedRide General Yaris / Vitz Discussion 4 07-13-2009 10:38 AM
aftermarket dead pedal dtappe4926 General Yaris / Vitz Discussion 12 03-19-2009 01:38 AM
Gas pedal fmicle DIY / Maintenance / Service 12 03-31-2007 12:08 PM
Pedal covers and dead pedals.. what is out there we can use? largeorangefont Cosmetic Modifications (Exterior/Interior) 8 01-15-2007 04:55 PM
