Old 03-06-2010, 12:06 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Pedal just stuck!
What the heck! I was doing 15 mph and took my foot off accelerator pedal and it kept going! I had to press hard on my brakes and it dislodged itself. I have a 2009 3-door which the VIN number claims was made in Japan. I will not drive it now, and I already had an appointment set up for Monday because of problems I am having with the brakes.
Twistoffate0817 is offline
Old 03-06-2010, 12:43 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
"dislodged itelf"...
Hmmm, was it stuck with the mat? Why not kick it into neutral and then apply the brakes?
That is my first reaction...kick that clutch in.
― Thomas Paine
sqcomp is offline
Old 03-06-2010, 12:58 PM   #3
Twistoffate0817
I took my mat out a few months ago, so no there was no mat. Since day 1 this car has been acting weird and have had it into the shop a few times. This just is another one of those freak things. As for the whole neutral thing, I was going to do that if the car would not stop. (I was in a neighborhood so no traffic)
Old 03-06-2010, 01:00 PM   #4
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
So the pedal was stuck, was there anything that it may have got stuck on?
slothman86 is offline
Old 03-06-2010, 01:09 PM   #5
Twistoffate0817
There is nothing down there it could possibly get stuck on. While the car was off, I pressed the pedal down as far as it could with my hand to see if it could get stuck on anything. I am hoping that it was just a one time incident, and will have it checked out on monday.
Old 03-06-2010, 01:14 PM   #6
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
strange..i've had my clutch pedal feel like it was stuck, but that due to WalMart bought plastic weatherproof mats over my Yaris mats...it would only happen if i pulled the mat too much forward towards me..
Kioshi is offline
Old 03-06-2010, 01:28 PM   #7
auxmike
auxmike's Avatar
Was the actual pedal part stuck so it was'nt spring back up, or did it feel like an electrical thing?
Also, auto tranny or stick+ do you have cruise control?
Please let us know what the dealer says.
auxmike is offline
Old 03-06-2010, 01:28 PM   #8
Only time I felt any pedal get stuck was with some rubber floor mats from Wally World. Since then I never ran the mat on the driver's seat and it never happened again.
Kaotic Lazagna is offline
Old 03-06-2010, 01:29 PM   #9
DandiDani
DandiDani's Avatar
wierd. no problems with my 09 lb here. made in japan also
DandiDani is offline
Old 03-06-2010, 01:48 PM   #10
AzNguy
Drives: Toyota Yaris Sedan 2009
do i hear, yaris recall?
AzNguy is offline
Old 03-06-2010, 01:53 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This doesn't sound good at all...
I've had no problems so far (07 LB), but I would still like to know what the dealership tells you.
Please keep us updated!
tk-421 is offline
Old 03-06-2010, 02:02 PM   #12
tomato
tomato's Avatar
+1
tomato is offline
Old 03-06-2010, 02:08 PM   #13
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
so far there has been no Yari recalled... I would bet this is an isolated event...
CtrlAltDefeat is offline
Old 03-06-2010, 02:10 PM   #14
ddongbap
That can't be good. Its not exactly easy to yank the car into neutral when you have a manual, with power applied from the engine.
ddongbap is offline
Old 03-06-2010, 02:20 PM   #15
tomato
tomato's Avatar
use the brake, use the e-brake, or can't you simply cut the engine off by turning the key?
tomato is offline
Old 03-06-2010, 02:21 PM   #16
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Nobody has asked the most relevant question: Was the engine warmed up or was it cold? What was the ambient temperature?
The Yaris idles pretty high when it's cold, and the computer does funny things sometimes when you're on/off throttle, especially when it's cold.
Stuck means stuck. If you take your foot off the gas and put the clutch in or the transmission in neutral and the engine continues to race, THEN it's stuck.
Loren is offline
Old 03-06-2010, 02:22 PM   #17
Loren
What?
Loren's Avatar
The throttle sticking doesn't disable your clutch, does it?
If you have a manual, just push in the clutch.
Loren is offline
Old 03-06-2010, 02:24 PM   #18
CtrlAltDefeat
I ♥ Yaris
err unless I'm missing something, pressing the clutch in should make it easy to put it into neutral on a manual...
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Dead pedal? RedRide General Yaris / Vitz Discussion 4 07-13-2009 10:38 AM
aftermarket dead pedal dtappe4926 General Yaris / Vitz Discussion 12 03-19-2009 01:38 AM
Gas pedal fmicle DIY / Maintenance / Service 12 03-31-2007 12:08 PM
Pedal covers and dead pedals.. what is out there we can use? largeorangefont Cosmetic Modifications (Exterior/Interior) 8 01-15-2007 04:55 PM
