Old 04-21-2010, 09:43 PM   #19
Originally Posted by Loren View Post
The Yaris sedan doesn't exist in my world.
Yeah, I can see there would likely be a few interior panels to remove in the back of a sedan.
hahahahaha
Old 04-22-2010, 12:06 AM   #20
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Took me 2 hours to do front back on HB.......but I have installed a lot of lowering springs to Toyotas.......shop will probably charge you 4 hours.
Old 04-22-2010, 12:18 AM   #21
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Hmmm... I have honestly never seen a sedan up close (other than driving one for my test drive). This will probably not help you but I recently did a spring install (also exhaust and CAI) on another users LB with only hand tools no air or electric tools to help and the whole process took 2 hours in my garage.
Old 04-22-2010, 01:07 AM   #22
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
sounds like sedan is more bitch to install the struts...lol oh well we'll try.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 04-22-2010, 01:41 PM   #23
MUSKOKA800
MUSKOKA800's Avatar
Pulling the interior trim is a bit dicey. Many of the fasteners are hidden/conceiled. Even service manuals don't clearly show removal techniques.
Take a leap of faith and you'll be fine. Mine all when back together without leaving a trace.
Old 05-15-2010, 03:34 PM   #24
britishbikes
Drives: 2008 Yaris Sedan
The rear shocks on Sedan are easy, just pop a few interior panels loose and then a few easy to get to bolts and nuts. The fronts are much more involved. You need spring compressors have to disassemble major parts of the front suspension. Then you have to realign the front end. I took mine to a front end shop for the fronts because of logistical reasons, they charged me $235 to change the front struts and springs and then align the wheels. The whole job took around two hours for extremely competent and expereinced mechanics with all the best tools. I have done the job on other cars when I had the time. I with typical shade tree tools expect to spend around 1/2 a day for both ends, not including the trip to the alignment shop.
britishbikes is offline   Reply With Quote
Old 05-15-2010, 03:57 PM   #25
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Haha... this thread makes me laugh. My friend at the dealership did the front and rear in about an hour. Even if you have issues I couldn't see it taking more than 2hr for a technician who knows what they are doing. DIY, I would expect about 5hrs with breaks. a lot of place just don't like doing aftermarket jobs like this, or they go by the reccomended time, not the actual time. Like if you have an lof that takes 4hrs cuz the tech is retarded they wont charge you for that much time, but on the downside if a 4hr job taks an hour and a half you still get charged the 4hrs.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-16-2010, 03:52 PM   #26
britishbikes
I can't see doing both ends with- one mechanic- and realigning the wheels in one hour. If your friend CHARGED you an hour, then he did you a favor.
Think about it, it takes about 1/2 hour to align the wheels, so that leaves him 1/2 hour to change two struts and two shocks, and replace the rear interior panels over the top of the rear shocks. That means that it took him, according to you, 7.5 minutes per corner of the car, including clearing the shop space for the next job. If you can change a strut and spring in 7.5 minutes, then perhaps you have your pick as to which shop you work.
Also there is nothing more difficult about the TRD suspension than there is changing the stock parts, so there should not be any premium for that. That day it was done, I saw the car go on the rack at about 7:00 am, they had the parts installed and aligned, plus a test drive by about 9:00 am.
Some guys I have seen etch out the spot where the camber plate went when they change the strut, in lieu of aligning the wheels, but that is never very accurate, with variations from the old part to new and also how the parts are positioned at the moment when the bolts are tightened. Were your wheels actually aligned in the deal?
There is almost always more to a job than you can see from here (online).
PS I remember the car was on the rack by 7:00 am; according to the sales ticket I paid at 8:47 am.
Old 05-18-2010, 01:08 PM   #27
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
I just finished installing the rears, and rears only for a scary reason which I will get to.
Rears took about 2.5~3 hours, not counting break and searching on the Internet to tackle a few problems that we had.
Front I assume it's gonna take longer than this and we are expecting about 4hrs+ to get it done. The reason why we couldn't jump on to start the fronts was...
When I popped the hood, on the top hat of the driver side front strut, one of the two bolts sticking out, was missing.
Upon a closer inspection, I found out that one of the two bolts sticking out towards engine bay has been completely snapped off and missing.
I think it happened when I took a pothole hard. If not, it would be me taking it a little too hard on corners as I take the car out for a spirited driving time to time on a regular basis. Whichever may have caused the breaking, it is scary to think what may have happened if the remaining bolt snapped off when I am driving...
Anyways, ordered that part from the dealership and it should be in a few days. As soon as I get it from them, we gonna start working on the front.
Old 05-18-2010, 02:51 PM   #28
The front struts only have one bolt and nut on top. got a pic of that?
Not sure what you mean by bolts "sticking out towards engine bay"
Old 05-18-2010, 07:08 PM   #29
RacerFreakXXX
JDM Fred
He actually did both ends for free in an hour, just no alignment. I can see it taking 2hrs with an alignment, however I didn't need one and I don't see why you would unless you were changing camber or toe.
Old 05-18-2010, 07:22 PM   #30
Astroman
Modded Moderator
Astroman's Avatar
I got an alignment done after I did springs. It was off a little.
Old 05-18-2010, 07:54 PM   #31
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
yeah my fault for a vague explanation, but once i get the picture up you will know what i am talking about. gave me cringes after finding it out
Old 05-29-2010, 11:01 AM   #32
britishbikes
Racer Freak:
The reason you align the wheels when you change struts is because the strut controls the camber. If you remove the strut and put a new kind in with different springs and geometry it also affects toe, because the distance from the steering rack to the spindle is changed as the lower control arm is now sitting in a different part of its arc.
It only takes a degree or so to speed tire wear, but in the short term, you may not notice much. If your tires are not wearing abnormally, of course taking into account that driving fast around corners will wear the edges more, then you should be fine with the alignment.
Old 05-29-2010, 11:21 AM   #33
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Don't cringe, just think carefully about how that upper mount works. Most of the time (I dare say 99% of the time, as even those of us who do motorsports very rarely ever "get air" with the front of the car), the weight of the car is holding the upper strut mount into a tightly fit sort of conically-shaped hole in the strut tower. It ain't going anywhere, even if you didn't put the nut on the end of the strut! (might make a little thunk when you hit a good sized bump, but that's about it)
The nut on the end of the strut is there merely to support the weight of that strut, hub and wheel assembly when the suspension is in full droop. It's more than up to that task.
It's a brilliantly simple design, really. It's that kind of reduced-part-count and easy-to-assemble engineering that allows them to sell the Yaris for a relatively cheap price.
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 04:49 AM
TRD springs - installation questions GrimlockGT Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-10-2010 10:12 AM
3Drive E-throttle (NTD/Shadow) With Installation ! micquek Items for Sale by private party 1 12-31-2009 06:21 PM
Yaris radio installation kit????????? Yarisguy13 Great Lakes 2 06-03-2007 09:24 PM
