Old 03-08-2010, 09:54 PM   #1
GrimlockGT
GrimlockGT's Avatar
Drives: 2009 3DR Blizzard Pearl CE
TRD springs - installation questions
Hi
I just picked up my TRD springs for my '09 3DR and looking at the installation documentation that came with it, I have a few questions.
The install shows that I need 4 replacement nuts and I should discard the old ones holding in the front springs. Is this necessary?
Where can I get the spring tape? Just ask at a local parts store (I'm in Canada).
I have 17x7 with a 42 offset rims with 205 40 17 tires. Will this setup rub?
Thanks
Chris
GrimlockGT is offline   Reply With Quote
Old 03-08-2010, 10:20 PM   #2
mario98c
mario98c's Avatar
You don't need to discard the bolts that came with the yaris and for the spring tape i dont known if is necessary but i don't use it in my springs.
Old 03-09-2010, 01:19 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
I bought new nuts at the stealership prior to starting the job. They're not expensive.
Later I found those I removed looked identical but put in the new ones anyway.
Regarding spring tape. I don't recall that mentioned in my TRD instructions so never used any. In fact, I've installed lowering springs on several cars and have never heard of the stuff???
Below is the PDF version of the Yaris TRD spring instructions courtesy of Sparks. I see no mention tape.
http://www.trdsparks.com/install/PTR11-52070inst.pdf
Old 03-09-2010, 01:29 PM   #4
you don't need to swap nuts or use spring tape
just swap springs and thats it
Old 03-09-2010, 01:36 PM   #5
GrimlockGT
GrimlockGT's Avatar
I was looking at a different TRD spring installation document and it showed tape. I looked more closely this time and the tape is used to protect the coating when compressing the new springs.
I think I found the document on this site.
Old 03-09-2010, 02:31 PM   #6
where did you buy these springs? Just wondering if you have TRD USA springs or Toyota Canada lowering springs which are really Eibach Prokits. Either way, you shouldn't need a spring wrap.
Old 03-09-2010, 02:36 PM   #7
GrimlockGT
GrimlockGT's Avatar
I bought the springs at the local Toyota Dealership in Dartmouth, NS. They were shipped in from Toronto. What is the difference between the TRD USA and Toyota Canada lowering springs? Mine are red if that helps.
Old 03-09-2010, 03:09 PM   #8
TRD springs are red with a 1.25" drop. Toyota Canada springs are black with a 1" drop.
Old 03-09-2010, 03:16 PM   #9
GrimlockGT
GrimlockGT's Avatar
I got the right set then
I used the part number from the TRDUSA website when I ordered them.
Old 03-09-2010, 04:06 PM   #10
are they red or black? lol, do they say eibach on them like my toyota canada springs do?
Old 03-09-2010, 05:08 PM   #11
GrimlockGT
GrimlockGT's Avatar
Red
Old 03-10-2010, 10:12 AM   #12
then they're "genuine" trd springs...
still no wrap req'd
Do the bump stops need to be trimmed with TRD springs? schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 07-10-2009 07:45 PM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
TRD shocks with tein or trd springs? UKblackyari Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-20-2008 12:20 AM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
