#1 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
^ I agree with almost all of that.
I'm a confirmed Clutchmasters fan now, I've used both and it's just a better clutch.
#3 |
Slowy getting there
If your goal is only 130-140ish HP why not go stage 0? No intercooler and run a water/meth kit. You are probably only going to be running 5psi.
#4 |
A meth kit isn't cheap to buy and to install and you need to refill it when it's needed. An intercooler has no day to day to take care of and costs about the same compared to an average intercooler
#5 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
I'm scratching my head trying to figure out why, with the given goal of 130-140whp, you don't just go with a readily available and proven supercharger kit. You'll end up spending more on a custom turbo kit in the long run.
Expand your $2500 budget to $3000-3400 and you get a plug & play kit that meets your goals without trial and error. If you want MORE power than that, then you need to go through the trials and tribulations of a custom turbo kit, fuel management, possibly forged internals, lower compression pistons, yadda yadda. But, if all you want is 130 hp... |
#6 | |
A couple things regarding this.... First, the blitz will not put down a buck thirty by itself. "Turbo" magazine installed it and only got to 119hp. Link Here. Secondly, there is very little upside to the blitz. If you want more boost, you first have to convert it to fixed pulley, instead of electronic, which is unproven ground as, to my knowledge, noone has done it. Then, you have to drop to lower comp pistons, since more boost on our factory 10.5:1 pistons will cause issues. Past that point, the s/c is capped at a (roughly) 9 to 10 psi on the housing before you leave the safe operating range. At the very least, you would need to run s/c with additional bolt ons.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#7 |
^ these are good points.
Meth kit is about $300, and a gallon will last for weeks, just to be clear. I'm not saying its necessary, either. You'd have to tune for it, which means management. I don't think it is needed for 130-140, probably can do that with a Stage 0 and no water/meth.
#8 | ||
Um, since you already got an intercooler (see #3 above), you are building a stage 1. Right? Quote:
#9 |
Just buy the hks turbokit for the xa/xb and modify the downpipe $2700
#10 |
#11 |
JDM Fred
I know no one has done this, not even the xb guys. I am better off with chinese turbo kit than I am a hks kit. I'm going to go with garms well built parts and get custom piping locally. Also, buying an engine is out. If I had a garage I would just buy a spare engine and build it and then swapp it, but I'm going to still consider it if I can find a place to do the swapp.
For EMS... I'm probably going to go with greddy, seeing as it has been proven. In all honesty I am going to get a greddy RS BOV unless I cant fork up a coupple hundred dollars. For turbo's, I think Garrett is going to be my best bet for the price. If I can find a new turbo for $400-$500 then maybe, but I doubt I will find a dual ball bearing water/ oil cooled T25 turbo for that much. Garm if/ when you make a downpipe, you should have the option to put on a bung for a/f sensor.
1990 Mazda Miata... I miss my Yaris
#12 |
My downpipe will have TWO bungs. One for managemenet, one for a gauge, and tuners love an extra bung for dyno day.
#13 |
JDM Fred
Nice... look at you thinking ahead, making life easier. I don't get why manufacturers make parts so expensive but they still need to be modded. I look forward to your kit... will you be making piping for a front mount intercooler?
#14 |
JDM Fred
what are your opinions on the 16g turbo? I was thinking something small like this:
http://www.dsmparts.com/customer/pro...cat=166&page=1
#15 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
A Mitsi 16G turbo is a 300+ hp turbo (both small and big 16g's) and don't really start to get efficient until 17+psi. Waaaaaay too big for your application.
Even a standard 14b Mitsubishi Galant VR4 (DSM Talon/ Eclipse) turbo is a 200hp turbo and might be too large considering it's designed for engines with a capacity of 2litres. A TD04 off an auto version would be better suited but you would need to find one second hand and have it rebuilt just to be safe. I can't think of any Mitsi turbo's that would be "ideal" for your application and would probably stick with a bb Garrett, or, dunno if you get them over there, one of the small IHI turbo's off a late '90s Subaru WRX, they were quite small and guys use them as big upgrades on Starlet GT's over here as they are plentiful and cheap. |
#16 |
JDM Fred
I'm going with the perrin fuel rail, as listed in my first post. My main concern are the oil likes and vacume lines and all of that little stuff. Should I tap the oil pan or buy an aftermarket?
#17 |
Mine Turbo Oil Feed is tapped into the lower block.... just a few inch below the knock sensor position ( behind intake manifold )
#18 |
We don't really have an oil pan, it's more of a plate; you would have to tap the lower block (like I did). Or get a deeper oil pan, but then you will have the worry of clearance issues when driving around.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 06:46 PM |
