Old 11-10-2010, 07:58 PM   #19
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by RobinNJ View Post
I have a 2007 Yaris coupe
I would take the car to a certified shop to have them deep test your battery and also your starter components. They will be able to tell you for sure...you could lean toward battery replacement, but best to be sure.
Old 11-10-2010, 09:48 PM   #20
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I have a 2007 Yaris coupe and I am now experiencing a really slooooowww crank, then it starts. I tried to see if the lights dimmed in neutral, partially turned the key, but nothing different happened. Half turn still starts the car and completes the ignition, it's just that it is chugging slowly to start? I can think of only three things: battery, alternator, or starter motor as the problems. I have 67k would the alt and the starter still be covered under warranty? I mean, 3 yrs and the alt or starter goes?
help in NJ
probably the battery, but you can go to a shop and get that checked for free.
Colin Chapman disciple
Old 11-10-2010, 11:54 PM   #21
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
My buddy's 04 Echo is still on its original battery, shows no sign of fading. More often than not, the charging system is going to do more damage than anything else by under- or over-charging the battery.
Old 11-12-2010, 01:09 PM   #22
Astroman
Modded Moderator
Astroman's Avatar
Four years, a couple days over to be exact. Didn't die on me, but it was time as I was having a hard time starting.
Old 11-12-2010, 02:08 PM   #23
nemelek
DWEED
nemelek's Avatar
I get a least 4 years out of my batteries. For me, once a battery goes dead it is never the same. Check the level once a year and seldom add water.
Old 11-12-2010, 04:19 PM   #24
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
5 years still running, no sign of bad battery, i can't wait until it die so i can replace it with yellow top, too much wires running to that poor old battery.
Old 11-12-2010, 05:14 PM   #25
xbr3akd0wnx
Meow
Drives: 2008 Yaris, White Hatchback
My battery just died last night :[. A little shy of 3 years. I noticed my doors werent locking and the 'lock' and 'unlock' thing on my key wasnt working either. After a stop at CPK, the car didn't run </3.
xbr3akd0wnx is offline   Reply With Quote
Old 11-13-2010, 10:07 AM   #26
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
OEM Battery in 2003 Corolla CE(April Delivery) going strong.
Killchain is offline   Reply With Quote
Old 11-13-2010, 09:17 PM   #27
Morgan
Morgan's Avatar
Drives: 07 MM LB
Weird, my battery died like two weeks ago. Can't really complain, it gets pretty hot here and I take lots of short trips. But FWIT: 4 years old, 65k miles
Old 11-13-2010, 09:23 PM   #28
bankrobber
Drives: 2007 Yaris Hatchback
I got 3 years and it died. Been cranking fine then I stopped at gas station and it wouldn't start back up. Had to push start it myself. At least this car is not too heavy to push for one person. 3 years is normal in Florida with the heat
Old 11-15-2010, 04:46 AM   #29
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
All I can Say is my battery lasted around 30 months, but it may be because of the sound I have.....
It went this winter past, (may, June, July in SA)
Batteries tend to die in either cold or hot conditions when the life span is over,
when there are what seem like electrical issues like weak ignition and poor starting, then look at the battery, I would recomend replacing with a sealed calsium battery as well.
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 11-15-2010, 05:03 AM   #30
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Sold my 01 echo in 08 with original battery running fine.
05 Echo still has original battery and shows no signs of age.
08 Yaris original battery,no problems.
Old 12-06-2010, 09:39 AM   #31
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
190,000km 4 1/2 years and my OEM battery is still working. And that is with crazy cold winters.
devinlamothe is offline   Reply With Quote
Old 12-06-2010, 12:13 PM   #32
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
more like 5-7 years.... but can go 10 years too.
Old 12-07-2010, 09:33 PM   #33
metalshark
MetalShark
Drives: 2008 Yaris LB
battery disappointment
I just replaced mine at 2 years 10 months. To add insult to injury Toyota put in a battery that was 7.75" tall. All standard G35 batteries here are 8" tall. I had to hack saw the rear hook off the battery hold down and braze it back on .25" lower. First incidence of Jap-Crap engineering I've run into except for the obvious tachometer and rear seat rip-offs.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 12-14-2010, 02:36 PM   #34
RedStickHam
RedStickHam's Avatar
Drives: 2009 Toyota Yaris
I've had my Yaris since February 2009 and the battery is still working fine.
As for other cars I've owned, I had a Ford Escort LX that went 5 years on the factory battery. I also had a Ford Escort GT that gave me around 4 years. My Hyundai Accent from 2003, I only got around 2 years, but found out from a newsgroup posting that there were many 2003 Hyundais with premature battery failures because they used a cheaper supplier.
The most I ever got out of a battery, and it wasn't a factory battery, was around 7 years. Can't remember what brand it was, but wish I could find another one of those.
RedStickHam
RedStickHam is offline   Reply With Quote
Old 12-14-2010, 02:42 PM   #35
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Originally Posted by metalshark View Post
rear seat rip-offs.
What rear seat rip off?
teddy is offline   Reply With Quote
Old 12-14-2010, 08:46 PM   #36
NinjaPirate
n00bcake
NinjaPirate's Avatar
Drives: 07 Yaris YR hatch
My car was built in Jan 07. Assuming they put the battery in at that time, it's coming up to 4 years. Last week I got it tested, still ok @ 385 CCA.
NinjaPirate is offline   Reply With Quote
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
How long does the battery in the remote last? yaris-me General Yaris / Vitz Discussion 18 01-31-2010 01:44 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
simota or stock? JapRulezz Performance Modifications 20 03-04-2009 07:52 PM
looking to buy or trade for stock exhaust shinlee Items for Sale by private party 9 12-11-2008 04:31 PM
