Old 08-19-2010, 04:57 PM   #19
Zamal7591
Drives: TRD turbo vitz
I'll check it , Thanks , Do u think its the same as the ECU 1 NZFE T????
Zamal7591 is offline   Reply With Quote
Old 08-19-2010, 05:00 PM   #20
Should be.
Old 08-19-2010, 05:06 PM   #21
Zamal7591
Btw can i get a picture of it , please?!!!
Or a plan?!!!
Old 08-19-2010, 05:22 PM   #22
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
but the arrangement of the wires on my ECU is completely different as mine is a turbo. its the same 1nz-fe engine but with factory fitted turbo. the code of my ecu is 1nz-fet. its does have 4 connector and does have a purple wire with white tracer but not in connector b and pin 17 as stated. shall ill try to connect it to the wire though?
btw thx for ure help. much appreciated.
Originally Posted by Bluevitz-rs View Post
No need for the PMs...
It's a purple wire, but I don't have my EWD on hand to tell you what connector... I'll see If I can find it.
Edit: ok found it. I have a '04 manual, so as long as you have a 4 connector ECU it should be the same. It's a purple wire with white tracer, pin 17, connector B.
ali077 is offline   Reply With Quote
Old 08-19-2010, 09:05 PM   #23
On my EWD, it's the only purple with white tracer on the ECU, so if that's the only one on yours, then it would be safe to assume it's the same.
Engine intake air flow not smooth on certain speed and gear? ammophobia DIY / Maintenance / Service 3 07-17-2009 03:31 AM
