Old 07-28-2010, 12:34 PM   #19
Hershey
Could it be that the factory fill of oil treats ( cures ) the gaskets and seals and dumping it too soon ( before 5,000 mis. as stated in O.M. ) could cause leaks ? Now that TOYOTA is going to 5w-20 ( dino and syn ) and 10,0000 mile O.C.s possibly more leaks will spring up . Maybe more cases of sludge or the gunk found in the pan above . Looks like plenty of deposits in the cynlinders and pistons as well . Longer intervals and lighter oil don't sound to promising from the pics provided by 2007tRD .
Old 07-28-2010, 12:43 PM   #20
sleey0
Drives: 2008 Yaris LB
Toyo is going 0W-20 synthetic for the 2010's.
sleey0 is offline   Reply With Quote
Old 07-28-2010, 12:43 PM   #21
Hershey
maybe we're being PUNK'd . Be better if we were .
Old 07-28-2010, 12:45 PM   #22
sleey0
And, knowing some walmart employees, I bet that oil hasn't been changed in years.
They probably just slapped an oil change interval sticker on the car without ever changing the oil.
Sad but it happens.
So let's not bash the owner too much;)
Old 07-28-2010, 12:49 PM   #23
127.0.0.1
in the pics
the goo in the pan is water contamination
the carbon on the cylinders looks pretty normal
I do not see much sludge. sludge looks like shredded burnt toast covered in oil,
...black carbony grit....not much of that anywhere in the pics
Old 07-28-2010, 12:52 PM   #24
Hershey
2007tRD , could you possibly ask the owner what brand of oil , the weight , conventional oil or synthetic or both , and the intervals they used ? Thanks again .
Old 07-28-2010, 12:53 PM   #25
Hershey
Originally Posted by 127.0.0.1 View Post
in the pics
a slow internal head gasket leak ?
Old 07-28-2010, 12:55 PM   #26
127.0.0.1
yeah that could do all that, plus the extra carbon deposits on the left hand cylinder where you said your oil leak is
Old 07-28-2010, 12:56 PM   #27
sleey0
A good synthetic can clean some of that engine out.
not the pan though...
Old 07-28-2010, 01:10 PM   #28
Hershey
Originally Posted by 1stToyota View Post
+1
Compare OEM GM V8-V6 plastic/silicone intake gasket vs the Fel-Pro steel/dense rubber version...funny how Fel-Pro fixes the known design flaws but OEM won't; guess it keeps the dealership busy with those steady $550.00-$900.00 intake jobs.
the FEL-PRO part number for the YARIS is FP26258PT . Works for XA and 1st gen. XB too .
Old 07-28-2010, 01:18 PM   #29
Hershey
Thanks . Didn't notice the extra deposits in that cylinder nearest to where our leaks are ( circled in red ) . Makes you think that this may be an issue for these cars . The '08 has had a bit of rough idle when stopped ( idling ) since we bought it . Leaking head gasket from the factory ?
Old 07-28-2010, 01:41 PM   #30
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Thanks . Didn't notice the extra deposits in that cylinder nearest to where our leaks are ( circleed in red ) . Makes you think that this may be an issue for these cars . The '08 has had a bit of rough idle when stopped ( idling ) since we bought it . Leaking head gasket from the factory ?
I don't think your leak is widespread issue. I have an 08 LB and run synthetic. No leaks. So yes this may be an issue with a certain number of cars or you just got unlucky.
Old 07-28-2010, 01:50 PM   #31
RedRide
RedRide's Avatar
Sad but it happens.
A dip stick is your friend.
It's a crude and primitive device but, it can tell you a few important things about your oil. A good owner is aware of this
Old 07-28-2010, 02:21 PM   #32
YarisSedan
Drives: 08 Yaris Sedan
Havent read all the posts but that blob is because of water and oil mixture. IE head gasket failure. Any valve cover you remove no matter how frequent the oil change will have that glob if there is moisture contamination. Old mechanic trick when checking for head gasket failure is to remove the oil cap if you see a bunch of yellow glob on the inside of the cap chances are its head gasket. Another tell tail sign is yellowish muddy oil on the dipstick.
Old 07-28-2010, 03:02 PM   #33
Hershey
the glob looks to be in the oil pan . Wonder if the oil they mostly used was WAL-F*RT's SUPERTECH . Think that's from WARREN PETROLEUM PRODUCTS .
Old 07-28-2010, 03:07 PM   #34
Hershey
2007tRD , what's the reason for the teardown ? Rough idle ? Coolant loss ? Smoke from tailpipe ? Fluid from tailpipe ? Oil in coolant ? Coolant in oil ? Oil leaking from head gasket ( if so , where outside of the block ? ) or a combination of things listed . Thanks Again .
Old 07-28-2010, 03:23 PM   #35
sleey0
I just switched over to synthetic today (royal purple 5w30!).
Hopefully it will prevent these kinds of issues.
Old 07-28-2010, 03:43 PM   #36
Hershey
would think a glob that size would take many miles / months to form . Thus , if it's a slow internal head gasket leak many wouldn't be aware of it . The coolant resorvior level probably wouldn't move all that much and could be easily overlooked . Would think that the moisture from the slow internal leak would be burned off , so wouldn't affect the oil level to make for any concern . Last , I remember other members complaining of a rough idle . Hopefully it's not due to the head gasket for cylinder no. 1 or others . This is mentioned here , http://www.etimago.com/yaris/repairm...Mechanical.pdf under EM 4 .
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
