Old 07-27-2010, 08:44 PM   #1
2007tRD
CERTIFIED ASE/SUBARU TECH
2007tRD's Avatar
Drives: 2007 VIOS S
Exclamation Killer oil!
Hey guys, I had the privilage of tearing down a 1NZ-FE....and what i found was not pretty.The customer was NOT changing his oil regularly, and when he did...it was done at wal-mart or those fast lube places.The pcv valve clogged up,resulting in a severe amount of carbon in the cylinders.After removing the oil pan, I found this blob of yellowish sludge all arount the oil pick-up.Just thought you guys should know...i have pics, if anyone is interested.
2007tRD is offline   Reply With Quote
Old 07-27-2010, 09:19 PM   #2
Pics please...
Old 07-27-2010, 09:26 PM   #3
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Please post pics... now I want to replace my PCV valve each time I change my own oil and filter.
salmonz is offline   Reply With Quote
Old 07-27-2010, 10:33 PM   #4
Hershey
How many miles are on that YARIS ? Pics please . Thanks .
Old 07-27-2010, 10:47 PM   #5
Hershey
2007tRD , is removing the valve cover the only way to get access to tightening the bolts for the head gasket ? Do other components besides the valve cover need to be removed to get to them ( camshaft , etc. ) ? Are there any bolts oustside of the block to tighten or are they all internal ? We have oil leaking from the head gasket for both our YARIS . Hoping head gasket bolts can be checked for proper torque from factory and applied if needed to stop the leak for the YARII . Rather have the valve cover removed than both the heads . THANKS .
Old 07-28-2010, 12:35 AM   #6
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
pics...appropriated
Look at your own risk....and yes, the valve cover,water pump,front cover,timming chain and cams need to be removed to replace a head gasket.This engine has 102k miles.There is no need to replace the pcv valve at every oil change,a 5-gas can tell you if your engine is running out of spec.
Old 07-28-2010, 01:03 AM   #7
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Looks like contamination in the oil pan. Water or coolant possibly, but it is possible it was a problem with the oil itself.
Stove is offline   Reply With Quote
Old 07-28-2010, 01:45 AM   #8
Hershey
Wow , that's funky lookin' . Wonder what brand of oil was used and how often it was changed ? That's why we prefer new to used when buying . Be it CERTIFIED or not . Even though we have a 2010 and 2008 that leak oil from the head gasket . The 2008 is worse at 23,000+ miles . The 2010 seems to have slowed done . Great pictures and thanks .
Old 07-28-2010, 01:48 AM   #9
Hershey
2007tRD , can you tighten the head bolts to stop the gasket leak by only removing the valve cover ?
Old 07-28-2010, 02:14 AM   #10
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
does the usage of synthetic oil also produce sludge buildup? i know that the corolla's made in 2003-2006 had a very severe sludge problem here in Israel..
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 07-28-2010, 09:26 AM   #11
1stToyota
1stToyota's Avatar
Looks like cams will most likely be in the way.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 07-28-2010, 09:37 AM   #12
severous01
if the head gasket is leaking already, tightening wont fix it.
you need to replace it. and i'd suggest fle-pro gaskets, or mr gasket gaskets. i know everyone says "oem is better...bla bla bla" but fel pro does their homework. they've remedied leaks for GM, ford, toyota, chrysler, jeep, and dodge that i know of. they have awesome gaskets and i've never had a problem with any of their gaskets leaking.
any way, enough of that before you guys think i sell their stuff lol. any way, you'll need new head bolts as well. you cant' reuse them, they're torque-to-yield bolts...never reuse.
Old 07-28-2010, 10:37 AM   #13
1stToyota
1stToyota's Avatar
+1
Compare OEM GM V8-V6 plastic/silicone intake gasket vs the Fel-Pro steel/dense rubber version...funny how Fel-Pro fixes the known design flaws but OEM won't; guess it keeps the dealership busy with those steady $550.00-$900.00 intake jobs.
2008 Scion xD
Old 07-28-2010, 12:06 PM   #14
Hershey
the area in red is where it leaks under the gasket for the '08 and the '10 . Thanks to all for your input .
Old 07-28-2010, 12:10 PM   #15
Hershey
so much for an easy fix .
Old 07-28-2010, 12:12 PM   #16
Hershey
that sucks .
Old 07-28-2010, 12:21 PM   #17
Hershey
You'd think that there must be other YARIS , 1st generation XBs' , or XAs' with the same leak . Why just ours . I really believe that starting the the use of synthetic oil at 1,200 miles for both is the cause . I've looked at 2 XBs ( 1st gen. ) and 3 YARIS with higher mileage for same leak and were bone dry . The '08 with 23,000+ miles leaks more than the 2010 with 8,000+ miles . Figure due to the longer run of synthetic for the '08 ( up to 21,000+ miles ) than the '10 ( syn until 7,000+ miles ) . Now using conventional motor oil for over 1,000 miles for the 2 . Talk about sh*t for luck .
Old 07-28-2010, 12:28 PM   #18
toyo
Drives: toyota
my god, that car owner shouldn't be allowed to own cars lol
1st gen FTW
toyo is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
