Old 09-16-2010, 11:39 AM   #19
sleey0
Drives: 2008 Yaris LB
official is probably 5-6
Thanks you
I had my clutch replaced at 28,000 miles. Luckily it was under warranty. I had the TRD unit put in for $40. I have not futzed with the clutch myself, though.
Wow. Did you have to buy the clutch at the full price or did you get it for $40? That would be some deal!
sleey0 is offline   Reply With Quote
Old 09-16-2010, 10:55 PM   #20
vwtech
Drives: 09 jetta tdi dsg
the clutch swap shouldn't take more than a couple hours with a lift and tranny jack. i've dropped the clutch without dropping the subframe (but on an NCP61) it's almost easier to pull the whole engine and do the clutch on a bench, but that's my opinion of course.
I dont think it would be easier to drop the engine and trans but who knows. What is an ncp61 anyways? wow an extra 40 bucks for a trd clutch that dealer cut you a good deal.
vwtech is offline   Reply With Quote
Old 09-16-2010, 11:43 PM   #21
sleey0
Still an amazing deal. I can't believe the stealership let you do that.
More power to ya!
Now if only my clutch would go lol...
Old 09-17-2010, 07:40 AM   #22
yaris2010RS
yaris2010RS's Avatar
They paid for the replacement of the OEM clutch; I paid an upcharge of $40 to add the TRD unit.
what were the terms of getting it replaced under warranty?
Old 09-22-2010, 07:45 PM   #23
vwtech
finally got the correct input seal in and I removed the trans to find the input shaft seal is INSIDE the transmission. I had to completely disassemble the entire transmission to replace the seal the job took me 7 hours I'm just glad we had the 4 different pullers needed to remove fifth gear and pull the input shaft bearing out to replace the seal. everyone needs to take a peak under their car to make sure your not leaking gear lube as well.
on a side note the trans is very easy to pull and you do not need to remove the subframe.
Old 09-22-2010, 07:58 PM   #24
vwtech
the new clutch (sachs) also feels way better than the stock clutch it doesn't feel like an on off switch anymore I can now take off nice and smoothly.
Old 09-22-2010, 08:02 PM   #25
Originally Posted by sleey0 View Post
So, no one knows the approx labor hours for a clutch swap?
It's 4.4 on an Echo, so i'd imagine similar time on a Yaris.
(Directly from the Toyota Flat Rate Book)
Old 09-22-2010, 09:02 PM   #26
sleey0
Is that warranty hours or labor hours? Makes a difference.
BTW, You got a digital copy of Toyo's flat-rate book? :P
Might come in handy!
Old 09-22-2010, 10:27 PM   #27
My father works for Toyota Canada, so I asked him.
Old 09-23-2010, 12:24 AM   #28
sleey0
Got it and thanks:)
Old 09-23-2010, 08:00 PM   #29
auxmike
auxmike's Avatar
Wow, sounds like a bad design that's not readily servicable for something as simple as a little seal. DIY hell!
I wonder if Toyota would tend to replace the whole tranny vs. keeping a tech down for 7 hours changing a seal.
Kinda glad I got the auto though I originally really wanted the stick.....
Old 09-23-2010, 08:16 PM   #30
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
24k miles strong.. and clutch feels grreat.
alch3miss is offline   Reply With Quote
Old 09-24-2010, 12:28 AM   #31
donchae
noob-toob
donchae's Avatar
Drives: 2007 yaris 4dr sedan
Originally Posted by eazyace View Post
Just curious but do any of you have problems when shifting to reverse? Sometimes I get a weird noise when shifting to reverse and sometimes it's harder than other times even though the clutch is pressed all the way. Any inputs?
just got my 2007 yaris sedan about a week now, and i noticed the same thing.. i thought that there might be something wrong with the clutch/tranny.. hmm but it seems like almost everyone's experiencing it.
|| "it's a tough job, but somebody has got to do it" ||
donchae is offline   Reply With Quote
Old 09-24-2010, 08:10 AM   #32
Has anyone tried adjusting their clutch peddle freeplay and through?
Old 09-24-2010, 08:41 PM   #33
vwtech
mine does the same thing shift into another gear before going into reverse and it will shift in fine.
Old 09-25-2010, 12:22 PM   #34
kou
Drives: 08 lb
Yes i did adjust the pedal a little,i have very little play in the pedal now i did it because i wanted the clutch to engage sooner, it helps.I also relocated the switch behind the clutch.Now i can press it with my finger instead of having to slam the clutch to the floor on startup.
Old 09-25-2010, 11:17 PM   #35
sleey0
Good to know and THANKS!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
Old 09-26-2010, 02:41 AM   #36
yaris2010RS
Not sure I follow.
I brought it in because the clutch was chattering quite badly. They said it needed to replaced and it would be covered under warranty. I asked if I could pay the difference between the OEM clutch and the TRD unit, and they said OK.
oh it was chattering. lol, i wasnt sure if u wore it out and got it done under warranty.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
