Old 10-02-2010, 05:06 PM   #19
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Have you even put them on your car yet? That should give you an idea on how they will look. After looking at the back spacing, I think these wheels will be in the for sale section really soon. It's just too bad you drove 400
(One way or round trip?) miles and paid $50 for wheels that may not fit. Good Luck!
marlondog is offline   Reply With Quote
Old 10-02-2010, 05:49 PM   #20
33OH
Drives: '08 Yaris
to get offset you need to measure backspacing and forward spacing. subtract the forward spacing from the backspacing to determine how far off "center" the hub is. then convert that into MM.
remember, a 7" wheel is closer to 8" wide.
Backspacing - 2"
Forward spacing - 5 1/4"
Subtracted: -3.25"
Converted: -82.55mm?
And yes - it is exactly 8" wide.
Old 10-02-2010, 06:09 PM   #21
kimona
kimona's Avatar
Drives: 2014 White VITZ
A 7" wheel with a 2" backspace has ET-48mm. I see craigslist in your future.
Old 10-02-2010, 08:17 PM   #22
33OH
Drives: '08 Yaris
Yep, already on there. Still a nice money-making buy, not too concerned. Think I'll be able to get more than $50 bucks out of them. :)
Old 10-03-2010, 09:08 AM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by 33OH View Post
Backspacing - 2"
Subtracted: -3.25"
if the wheel is 8" wide, how are you not getting a back and forward spacing total of 8" ?
recheck your maths sir
also, are you SURE they're 4X100 and not 4X108?
Old 10-03-2010, 10:08 AM   #24
33OH
Drives: '08 Yaris
They're 4x100, I put them on my car. And the hub mounting surface is 3/4" wide, which is why my math comes up a little short.
Old 10-04-2010, 03:23 AM   #25
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
step 1: measure the full width of the rim in millimeters, end to end.
step 2: divide that by 2, that will give you the +0 (ex: width of rim 204mm. 1/2 = 102mm)
step 3: measure back side of rim from mounting point of rim to edge of rim.
step 4: subtract step 3 from step 2. That will be your offset - in your case it will be negative most likely.
Old 10-04-2010, 06:49 AM   #26
33OH
Drives: '08 Yaris
  1. 203mm
  2. / 2 = 101.5mm
  3. 50.8mm
-50.7mm
Old 10-04-2010, 10:52 AM   #27
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
50.7 is your +0 offset. That's if the mounting face was exactly dead-center of the rim. But I think on your wheel the mounting face is set back a bit from center right? -Like the pic on the right.
Old 10-04-2010, 10:54 AM   #28
33OH
Drives: '08 Yaris
Yep, it's 2" away from the rear of the rim. Way set back.
Old 10-05-2010, 01:15 AM   #29
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
2 inches away huh? That equals to about 50mm. 50-50= 0. I guess you were right in the first place, +0 offset it is!
edit: should be 101.5-50.8. I need to go back to school.
Old 10-05-2010, 06:27 AM   #30
Tamago
Tamago's Avatar
Drives: UZJ100
uhh
no
Old 10-05-2010, 08:11 AM   #31
33OH
Drives: '08 Yaris
Lol, it's definitely negative. I stuck one on my car and it stuck out about 5" or so. :)
Old 10-05-2010, 08:39 AM   #32
^ Did you take a pic of that? Would be hilarious to see!
Old 10-05-2010, 10:43 AM   #33
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
oops, my bad. Thanks Tamago. If it's 2" away, then -50 mm offset. Wow, that's crazy.
I'm with WeeYari - pics!
Old 10-05-2010, 11:18 AM   #34
33OH
Drives: '08 Yaris
Here ya go.
Old 10-05-2010, 12:35 PM   #35
Old 10-05-2010, 12:36 PM   #36
33OH
Drives: '08 Yaris
I could put 15 degrees of camber on and roll on them, just saying. :P
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
