#19 |
Sure buddy I'll get the info to you ASAP I have a buddy who did it and is rocking the Rav 4 rims not my taste but a good job at that, from what I know the stock hub is very easy to take off and you need a special rachet to do so, I'll pm you with more info
#20 |
![]() ![]() Drives: 2009 JDM Toyota Vitz Join Date: Jul 2010
Went to a Breakers Yard today, and managed to find a new Corolla there... Front end seems OK, and the Toyota Schematics show a similar setup, only problem is the Rear now because the Vitz has Drums at the Rear, but the Corolla has Discs... Grrrr!!!!
2011 JDM Toyota Vitz RS NCP91-AHMVK Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs... |
#21 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
I have a sneaking suspicion that the Scion XD rear trailing arm will fit.
#22 |
If I go the Corolla Option, what would happen if i transfered the Rear Disc Brakes setup across to the Yaris? Would it just connect to the existing Brake lines? If so, it could be a combo way of getting 5-lug and rear discs! Hmmmm!!??
#23 |
If someone could just find me a set of the 17" OEM Yaris TS Wheels it would make my YEAR!!!!!! LOL
#24 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
i wanted 3 bolts..if its possible less lugs and less weight..lolz...
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
#26 |
These are the ones I'm looking for....
#27 |
In microimage they sell the rear brake convertion, and those rims look nice
#28 |
Given up on the 5-lug conversion, after seeing the amount of work required to transplant the Corolla Hubs and Brakes across, just not motivating enough!!!
Still on the hunt for the above Yaris TS 17" Wheels though, ANYBODY have a set of these that they want to sell? Surely some of the TS owners are doing the aftermarket wheel thing??
#29 |
#30 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
in order to go from drum to disc you need to change out the proportioning valve. if not you'll wear the rears wayyyyyy faster than the fronts. it's set up that way to overcome the springs in the drums so the disc doesnt engage first....no springs, rears will engage first.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| $86.44 for oil change? I feel screwed | behour | General Yaris / Vitz Discussion | 98 | 01-04-2010 07:10 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
