Old 12-22-2006, 11:53 AM   #19
graywolf_14
Drives: um not a yaris but hopefully
If I had 15's I would only go with a 205/50/15 or a 225/50/15
graywolf_14 is offline   Reply With Quote
Old 12-22-2006, 03:00 PM   #20
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by bigsky2 View Post
I suggest caculating your overall stock diameter (wheel + tire), and then calculating the new overall diameter with your new wheel and tire setup.
For me, the stock setup was 185-65-R15, and the new setup was 205-40-R17.
I think there is a minor difference in diameter, and hence there is slightly more gap between the tire and my wheel well.
stock tires are larger in Canada? here in the states out stock size is 185-60-15 witch would translate to a 215-40-17
Old 12-22-2006, 03:01 PM   #21
Black Yaris
der Zeck
205-55-15 and 225-50-15 have the exact same over all diameter, I am running 225-50's and love em
Old 12-22-2006, 03:18 PM   #22
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Sorry, I screwed up the tire size there.
You are right, for the record:
15" Tire size = 185-60-15
14" Tire size = 175-65-14
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 12-22-2006, 03:22 PM   #23
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I have TRD Lowerin springs on my sedan and there's no rubbing even with 18''.
I'am looking foward on lowering it more but the streets here don't allow me to
here's a pic
I Drive a 129whp Yaris ;)
Old 12-22-2006, 04:54 PM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
i'd go Tanabe's
installing TRD springs voids your warranty just as quickly lol, unless you really wanna get raped by install prices from the dealer.
Old 12-22-2006, 06:53 PM   #25
jcove
jcove's Avatar
Drives: 2011 Rogue
Originally Posted by PetersRedYaris View Post
Look for pictures posted of Yari lowered with Tanabe NF210's on stock 15 steel wheels. The NF210's drop the car 1.3 inches, compared to TRD's 1.2 inches. I think the DF210's are to low at 1.6-1.8 inches. If I were you I would go for the TRD's or NF210's, thats what I plan on doing next to my Yaris.
My thoughts exactly, but I'm not going to put down the DF's. Those just aren't for me.
jcove is offline   Reply With Quote
Old 12-22-2006, 06:55 PM   #26
jcove
jcove's Avatar
Drives: 2011 Rogue
i'd go Tanabe's
Where did you get that idea, that the TRD springs void the warranty?
Old 12-22-2006, 09:57 PM   #27
johnnyfive
johnnyfive's Avatar
he was saying that your warranty will be voided with any non-dealer installed products that directly cause a problem with the car.
TRD, Toyota, Tenabe, dosnt matter, if the a dealer dosnt do the install ther is no more warranty ;)
Old 12-23-2006, 12:27 AM   #28
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Installing springs will void the warranty of what? The only thing affected would be the rear shocks and front struts which are replaceable parts anyway. How long does Toyota cover those parts in the first place? I would forget about voiding your factory warranty and install the springs you want regardless of brand. I do, however, like the TRD's best. Why?
DF210's- Too much drop for me although they are the most inexpensive.
NF210's- perfect amount of drop, cost little more.
TRD's- Perfect amount of drop and factory made for this car, cost about the same as NF210's.
Teins- way too much drop.
Amount of drop is purely individual preference but will affect handling.
Old 12-23-2006, 01:26 AM   #29
paultyler_82
Couldn't have said it better myself, one more thing you should take note of is how they affect the ride, and this is what I gather from others
DF210: Rougher ride than stock, stays much flatter in turns and braking
NF210: Comfortable ride, stays flatter in turns and braking than stock, although the rear springs may not feel firm enough
TRD: Roughest ride of the bunch, similar charactaristics to DF210
Tein: Rides about the same as the DF, very firm in cornering and heavy braking
I'd say this is about what I'd expect, I've never used Tanabe springs but everyone seems to sing thier praises on this car, most of the cars I've driven I've used Tein springs on, usually noticably rougher than stock, but handling charactaristics become very predictable and controllable. As for the TRDs... not to badmouth Eibach, as I know some people do like them, but I've always found them to be too rough, they will wear you down after driving with them for extended periods of time, and I've found they usually aren't the best in the market for improving handling, although they certainly do give an attractive drop, that's the problem, I've found Eibachs to be much more cosmetic oriented than comfort or performance oriented. Just listen to the other members reviews of the springs they use and make your decision with what you feel suits you best, I think I'll be breaking my tradition of buying Tein springs and going for a set of Tanabe NF210s
Old 12-23-2006, 01:32 AM   #30
PetersRedYaris
TRD's ride the roughest? Maybe I want the NF210's. This is my next mod and I don't want a rough ride.
Old 12-23-2006, 01:42 AM   #31
paultyler_82
it's what I've been meant to understand from a friend that tested the DF and the TRD and kept the DF, and it doesn't really shock me, it's been the same story on two cars I personally used Eibachs on, it took a week before I was installing a set of TEINs on both of those.
Old 12-23-2006, 09:22 AM   #32
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
NF's are for confo rides while still lowering A LOT
hystria is offline   Reply With Quote
Old 12-23-2006, 09:24 AM   #33
Tamago
Tamago's Avatar
Drives: UZJ100
1.5 is not a lot lol
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 08:25 PM
Fs: New Trd Stickers & Emblems !!!!! located in So cal Trd86 Items for Sale by private party 13 06-25-2007 04:49 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 10:51 AM
Toyota's Yaris TRD VitzBoy General Yaris / Vitz Discussion 10 07-24-2006 08:10 PM
