Old 02-22-2011, 03:55 PM   #19
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
the tps sounds like it works.
i found a function in the fic to switch the o2 map to be switchable with boost pressure. now just need to test drive to see how well it works!
it worked sitting in the parking lot, i was able to drop it down to 12.2 at idle.
so it is tunable, now just trial and error to see how well it works.
Scubaru Steve is offline   Reply With Quote
Old 02-22-2011, 04:33 PM   #20
Old 02-22-2011, 05:06 PM   #21
Focus_Sh1ft
Focus_Sh1ft's Avatar
I'm jealous lol. That's exactly what I wanted to do but could never get the O2 skew to work correctly.
Right. Yet. You're definitely shortening the life of the motor.
If that weren't so, Toyota would run the motor at that AFR too, and so would everyone else.
Definitely in agreement here, and was going to richen the entire map when the weather warmed up.
I always thought low 15 was safe because in closed loop the mixture would generally run on the leaner side of stoich, and go as lean as 15.4ish frequently. I probably should just be playing it safe rather than trying to squeeze out as much fuel economy as possible...
Old 02-23-2011, 09:19 AM   #22
Toyota does. Stock the cars (Toyota's in general) can run as high as 17:1 AFR while at cruise.
Old 02-23-2011, 09:21 AM   #23
This is what I was saying about the difference between the Yaris ECU and the Echo ECU. The Echo's is way more forgiving if it doesn't see normal values. The Yaris will freak out and correct them.
Old 02-23-2011, 09:36 AM   #24
Scubaru Steve
Awesome!
i dont know where you got you information... but 14.5-15.2 seems to be the norm at cruise. and thats the closed loop setting unless you start tuning that.
at 17 there is a severe loss of power. when we had the bogging issue thats where it was, then the ecu would dump fuel and suddenly it had a ton of power.
Old 02-23-2011, 01:46 PM   #25
Focus_Sh1ft
I'm just curious as to why you think this? Theoretically, if you're manipulating the AFR sensor's voltage, it can't really correct itself since it's the main method of fueling feedback (and therefore will think that everything is okay).
However, I definitely think the ECU might see continuous low voltage at the AFR sensor and throw a code. More importantly though, it probably would throw the engine into open loop. No one has really tested this method of tuning on the Yaris yet, so I'm just speculating.
Could this be where the Yaris and Echo ECUs differ?
Old 02-23-2011, 02:32 PM   #26
For one, the Yaris uses one AFR sensor and one O2 sensor. The Echo uses two O2 sensor, so it's not as smart when it comes to correcting fueling. That's why the Yaris has a better emissions rating than the Echo does.
And about the AFR running as high as 17:1. That's what I was taught at Toyota Canada during a training session a few years ago. It won't be 17:1 under any significant load, it's only under certain conditions like: crusing at 80km/h down a slight grade but you're still on the throttle. There's really no load on the engine, but it's not on DFC either.
Old 02-23-2011, 02:34 PM   #27
Thanks for clarifying that this is only under certain no-load conditions. Maybe this is what he was describing, but probably not:
I'm constantly running 15-15.5 out of boost, sometimes even slightly leaner
Old 02-23-2011, 02:46 PM   #28
All I was getting at is that it's possible to see a really high AFR while driving. As long as it's not under boost
Old 02-23-2011, 03:40 PM   #29
Focus_Sh1ft
Yeah sorry let me clarify... It's inaccurate to say that I'm running at 15-15.5 all the time outside of boost. Whenever I'm cruising I allow it to go that lean because it does seem safe to me since the engine is under a lower load than say, when under acceleration. I only say it seems safe because
1) under very low load the mixture goes as lean as 17-18 (DFCO). So shouldn't it be safe to run a little leaner than stoich at low loads?
2) like I said earlier, if you watch closed loop, it will go as lean as 15.4 WHILE CRUISING. Usually the AFR will hold more around 14.7 while accelerating. I attempted to emulate this behavior:
3) as I do approach a higher load on the engine, I keep the AFR under 15. And really, that's only under low load because I have a linear approach set up that begins when the manifold absolute pressure begins approaching atmosphere (and reaches 11.5 AFR by 5 psi boost).
I definitely am no expert on this, so my tune is largely from what I've read and assumptions like the one's above. My goal was to achieve a safe tune that maximizes full economy. If you guys think I have the wrong idea, please let me know.
Old 02-23-2011, 04:25 PM   #30
^ Hey I was going by what you actually said which was:
Now you are saying:
So, ok I guess we are good now
Old 02-23-2011, 08:59 PM   #31
Focus_Sh1ft
Sorry about that
Think about it though. With such a small turbocharger, pretty much anytime you give the engine a decent bit of throttle you're almost immediately entering boost. So really most of the time is either spent cruising or in boost anyways.
The lesson to be learned here is word choice means everything.
Old 02-23-2011, 09:46 PM   #32
hehe, onward then!
Old 03-04-2011, 09:06 AM   #33
Did you getting all sorted out yet?
Old 03-06-2011, 09:40 PM   #34
Scubaru Steve
Awesome!
well, the 02 map seems to work intermittently, at -27*C the car doesn't pull to hard, but... when its +5 i was able to keep up to a 350z, man was he shocked!
i need to do some more playing around and find a way to do some better tuning, will still need to do the exhaust, weapon r intake manifold, larger fmic and we have a greddy mbc to bump us up to 7psi.
Old 03-06-2011, 09:59 PM   #35
johnny_vitz
Drives: 2005 Toyota Echo
lol what was wrong with the 350Z?
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 03-06-2011, 10:38 PM   #36
Scubaru Steve
Awesome!
dunno, he had sweet sounding exhaust, car was painted flat black. i know there not that quick but i was expecting him to pull alot harder then what he did.
im gonna email greddy to see if they have a larger turbo that will bolt right into their kit.
Aem fic 1.5ty Forced Induction Forum 17 08-16-2015 07:22 PM
aem fic $280 1.5ty Items for Sale by private party 1 10-22-2010 11:06 AM
Aem fic 1.5ty Items for Sale by private party 24 10-05-2010 03:59 PM
AEM FIC works in Yaris......Sort of cdydjded Performance Modifications 32 12-06-2009 01:58 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 06:20 AM
