Old 05-22-2011, 02:49 PM   #19
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Thumbs up SUCCESS! DRL Works
Originally Posted by toy_toronto View Post
Thanks for the idea zuberio -- nice work!
I recently installed an HID kit but now missing the DRLs since I had to disconnect the relay underneath the dash. I'd like to get the DRLs back therefore I plan to do this relay DIY to my hatchback, but the difference is I just want to use the existing parking lights inside the headlights as the DRL lights (see pic below).
I'm going to be replacing the bulbs with the brightest/white 194's LED that I can find to make them more visible in daytime.
I've searched the forums but had difficulties finding the info... Do you have a link where I can find the hatchback headlights wiring diagram so I can splice the hi/lo signal source to the relay?
thanks!
-toy
Success
I didn't know that the sedan and hatch shared almost the same wiring. I went and checked the same fusebox and managed to splice the same wires to make the bulbs I wanted to use as DRLs work (i.e. parking/city lights inside headlights).
There's a slight difference though compared to which BAT wire zuberio used. I ended up tapping the brown wire (85) since it's the only one that switched LO (86) to 12V to energize the relay coil whenever I switched the headlights on.
Now I have my DRLs back! Now I just need to find the brightest LEDs to swap the bulbs with.
-toy
Old 05-27-2011, 02:18 PM   #20
toy_toronto
always toyin'
Drives: 2010 5-Dr
Well, the LED swap didn't make the lighting any brighter so I added a pair of dedicated DRLs and mounted them between the lower grill.
This pretty much concludes my quest for DRL (for now, haha).
-toy
drl, headlights, led, relays, wiring
our DRL is running in pulse............. marcus Cosmetic Modifications (Exterior/Interior) 14 06-21-2010 09:49 AM
Daytime Running Lights Module amtoro Willing to Buy by private party 1 11-13-2009 10:32 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 12:12 AM
Need Help Wiring Fog Lights MadMax Cosmetic Modifications (Exterior/Interior) 29 11-29-2008 06:31 PM
Daytime Lights NimbleYarisOwner General Yaris / Vitz Discussion 17 08-24-2007 09:07 AM
