Old 06-18-2010, 02:20 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
our DRL is running in pulse.............
been wanting to go hid but now i am running into cases where if i need to keep my drl and just run a relay will still cause issue with the hid due to a stupid drl pulse...need to run straight 12v current thru even on the relay. capacitor is an option ..but man what ever happen to plug and play..
Old 06-18-2010, 02:27 PM   #2
cut drl power
plug and play HID's
i just saved you time and money.
Old 06-18-2010, 02:38 PM   #3
yup.. i've had this problem where the DRL pulsed my fog relay... a cap fixed the problem.
the relay takes almost no power anyways... a 100uf cap will do the trick.
by the way.. i've already told you about the pulsed DRL...
Old 06-18-2010, 03:59 PM   #4
marcus
toyota
marcus's Avatar
OK UPDATE..just got back from this place where they sell hid and hid alone.. their digital ballast automatically shuts off drl plug and play for dual bulb u still got low beam hid and hi beam halogen..but im surprise no relay needed ..and yes we did try it out although i forgot to check my fogs if that was affected.... now since i didnt have time today ,tomorrow were testing bi xenon with built in relay and see if that works..
Old 06-18-2010, 04:22 PM   #5
what'd it run you?
Old 06-18-2010, 04:36 PM   #6
marcus
toyota
marcus's Avatar
if i go dual bulb hid/halogen...its $80
now hes letting me try the new kit bixenon built in relay on each harness that one is $120 but i think i get get it for a bill...well see tomorrow.
Old 06-18-2010, 09:15 PM   #7
ddongbap
Dude, 80 for a dual isn't bad at all.
Old 06-18-2010, 09:17 PM   #8
ddongbap
Sry, I thought you meant dual xenons.
Old 06-19-2010, 12:01 PM   #9
marcus
toyota
marcus's Avatar
hate the dual xenons you have to run 2 pair of ballast on them..
Old 06-19-2010, 01:17 PM   #10
there are 5 types of H4
1. single beam low...you lose your high beams
2. low beam HID w/ high beam halogen
3. low beam halogen w/ high beam HID (rare combonation)
4. bixenon bulb w/ hid high/low beams - - has mechanical bulb that moves
5. bixenon bulb w/ hid high/low beams - - has 2 hid bulbs, requires 4 ballasts
the most typical bixenon kit in my experience is #4 aka H4-3
Old 06-19-2010, 09:35 PM   #11
marcus
toyota
marcus's Avatar
Did option 4 but even with relay it's still flickering. Damn pulse drl
Old 06-20-2010, 04:51 PM   #12
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
as mentioned already, you just need a capacitor to smooth the output going to the relay. This will not work for ballasts directly connected to the bulb sockets without using a substantially large capacitor (and with the discharge-recharge phases it puts the cap under some stresses that are not ideal for this application), so the capacitor fix will only work for a relay harness.
taKuto is offline   Reply With Quote
Old 06-20-2010, 04:59 PM   #13
marcus
toyota
marcus's Avatar
Got this fixed just disconnected the blue wire in the drl relay it worked flawlessly
Old 06-20-2010, 10:51 PM   #14
I got it at the plug.. and had it rewired to the pin that connects to the orange wire...
Old 06-21-2010, 09:49 AM   #15
marcus
toyota
marcus's Avatar
i just unplug the blue wire and thats it..no rewiring needed..
DRL in Yaris from..? Falconia Cosmetic Modifications (Exterior/Interior) 36 12-22-2010 05:01 PM
DRL in Yaris from...? Falconia General Yaris / Vitz Discussion 3 02-25-2010 01:22 AM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
DRL disalbled. IllusionX DIY / Maintenance / Service 0 10-22-2008 03:16 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
