Old 02-23-2011, 08:57 PM   #19
ooh nice GROWL!
Old 02-24-2011, 01:17 AM   #20
yaris2010RS
yaris2010RS's Avatar
the rest of the exhaust was stock?
Old 02-24-2011, 07:54 PM   #21
06silveryaris
Drives: 2006 yaris
yes completely stock, to cut it without damaging the muffler you have to do it thru the center divide on the "pumpkin" . Look at the pics and you will see what I mean. BTW no drone sound in the car
06silveryaris is offline   Reply With Quote
Old 02-24-2011, 07:59 PM   #22
06silveryaris
Drives: 2006 yaris
BTW this is the exhaust before modification
http://www.youtube.com/watch?v=z237j..._order&list=UL
Old 02-25-2011, 12:46 AM   #23
Viperoni
Drives: 2005 Toyota Echo
Originally Posted by malibuguy View Post
nice to know whats inside
its kinda like a DynoMax VT muffler
Exactly, but the Dynomax is a lot more straight through.
That small trap door hurts flow a lot, and the glasspack part doesn't help flow enough either. Does do a great job quietening though.
Old 02-25-2011, 03:39 PM   #24
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Originally Posted by larryn2o View Post
i cut up a factory muffler this week , to see how it is made. it had 2 small "glasspak sections and a 180 bend in the pipe . not bad for flow. the bad part is a center divider with a small square door. it is spring loaded and was stuck almost shut. had to be beat open, this is after only 40,000 miles .
one could take a hole saw or large drill bit , make 1 hole in the rear of the muffler and perforate the divider to gain more flow. then patch the out side for a stock appearance.
quick question you said it was stuck correct. so the first pic is after you beat it open and the second pic is the before?
if so ever thought that maybe the flap would open toward the rear of muffler instead of towards to front? jus wondering
OTA'sTOY is offline   Reply With Quote
Old 02-25-2011, 04:00 PM   #25
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i didnt know our yaris has that door..i have to check my stock exhaust.
Old 02-27-2011, 02:17 PM   #26
Viperoni
On this note, has anybody ever dissected the midpipe's resonator?
Old 02-27-2011, 07:19 PM   #27
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
^ the resonator is straight thru
i was thinking about that valve being stuck...maybe it opens easier when its heated up with the exhaust
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-27-2011, 10:18 PM   #28
larryn2o
larryn2o's Avatar
Drives: 08 yaris
valve
it will only open one way , it isn't the only path for flow , after cutting more ,i can see a short gap in the pipe right before the glass-pac section.
larryn2o is offline   Reply With Quote
Old 02-27-2011, 10:54 PM   #29
Viperoni
I've seen that before in the mufflers on my old Buick Roadmaster.
Thanks for the reply on the resonator
Old 04-09-2011, 01:42 PM   #30
SilToYaris
SilToYaris's Avatar
Drives: Toyota YarisLE HB Silver 2009
Send a message via MSN to SilToYaris
Nice difference ;)
SilToYaris is offline   Reply With Quote
Old 05-08-2011, 10:12 PM   #31
larryn2o
larryn2o's Avatar
Drives: 08 yaris
i just put a 2 inch pipe on a stock flange and ran over the axle to a 2 inch Cherry Bomb turbo. it has an offset so the tip is in the stock location and it all looks stock ."in case the law has a problem with that stuff". it is just a bit louder than stock with no load, some what louder under load. nice sound , no popping or racking off. a noticeable increase in power . muffler $24 at Auto Zone , pipe bent ,muffler mounted and tip at local muff shop. $44. (total $66)
it ain't stainless , but I'll change it in a year or so anyway! :)
Old 12-05-2012, 05:46 PM   #33
larryn2o
larryn2o's Avatar
Drives: 08 yaris
http://www.youtube.com/watch?v=px6YO...IZJKvw&index=1
new setup twin tip on a 2 inch axle back. it's a pace setter knock-off , $35 at the local speed shop. not as good sound but 1/2 price.
I'm going to tune it a bit to see how it sounds.
Old 12-08-2012, 04:29 PM   #34
MUSKOKA800
MUSKOKA800's Avatar
Don't recall seeing any lubrication/service interval for that pesky muffler flap???
Must have missed that.
Old 12-09-2012, 02:14 AM   #35
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Muffler bearings: perhaps they do actually exist.
Old 12-09-2012, 02:17 AM   #36
yaris2010RS
Poor Muffler bearing care caused my front tire to go flat
TRD Muffler Keith Tinari Items for Sale by private party 20 01-31-2010 10:47 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 10:08 AM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
FS: OEM STUFF darkmoon87 Items for Sale by private party 2 05-29-2009 05:21 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 07:22 PM
