Old 02-20-2011, 05:17 PM   #1
larryn2o
larryn2o's Avatar
Drives: 08 yaris
oem muffler dissection
i cut up a factory muffler this week , to see how it is made. it had 2 small "glasspak sections and a 180 bend in the pipe . not bad for flow. the bad part is a center divider with a small square door. it is spring loaded and was stuck almost shut. had to be beat open, this is after only 40,000 miles .
one could take a hole saw or large drill bit , make 1 hole in the rear of the muffler and perforate the divider to gain more flow. then patch the out side for a stock appearance.
larryn2o is offline   Reply With Quote
Old 02-20-2011, 05:31 PM   #2
cool. glad someone did that so we could all see!
Old 02-20-2011, 07:00 PM   #3
yaris2010RS
yaris2010RS's Avatar
lol? u did that at work? i recongnize the rollers on the work bench, lol
i have been planning to open mine up and basically gut it out to get a little deeper sound, does it look possible/practical?
Old 02-20-2011, 07:28 PM   #4
auxmike
auxmike's Avatar
What's the deal with the hatch then?
Will the car still run if the hatch jams shut?
Old 02-20-2011, 08:27 PM   #5
RedRide
RedRide's Avatar
Interesting.
I was wondering what was inside one of those.
Thanks for posting it.
Old 02-20-2011, 09:03 PM   #6
larryn2o
larryn2o's Avatar
Drives: 08 yaris
there is a small gap in the in-feed tube so that it can flow with the door closed. you could take a hole saw and drill from the top. if placed right it would sever the outlet tube, and eliminate the trap door. that would make it a single chamber muffler.
Old 02-20-2011, 09:17 PM   #7
larryn2o
larryn2o's Avatar
Drives: 08 yaris
NOT ME !!
if you cut it open ,stay to the back side (rear)of the seam , the center partition is welded to the pipes and outer case. you could cut a 3 inch hole in the partition and weld in a racing header insert. this would make the equivalent of a turbo muffler.
http://www.summitracing.com/parts/SCH-42530/
Old 02-20-2011, 11:23 PM   #8
That trap door is supposed to be a performance thing. It's shut to keep the car quiet and maintain back pressure, but when you floor it the pressure is supposed to open it up allowing better flow at the expense of more sound. It's a pretty good setup when it works for a stock muffler.
Old 02-20-2011, 11:31 PM   #9
yaris2010RS
when it works? lol how do we know if it works or if its failing?
Old 02-20-2011, 11:55 PM   #10
I'm just going off of the OP saying his was jammed shut. I'm sure it'll work forever on a regularly used muffler.
Old 02-21-2011, 12:40 AM   #11
RedRide
RedRide's Avatar
Another reason to go for WOT often.
Old 02-21-2011, 12:47 AM   #12
yaris2010RS
im sure mine isnt stuck, i life at WOT and still get amazing fuel economy considering
Old 02-21-2011, 01:02 AM   #13
RedRide
RedRide's Avatar
Exactly.
Even at its worse, the Yaris still gets great milage.
You might as well enjoy what you're driving.
Old 02-21-2011, 01:24 AM   #14
detroiter
detroiter's Avatar
My yaris seems to like to suck down the gas if I jam on the gas pedal too much at WOT :(
Old 02-21-2011, 01:41 AM   #15
yaris2010RS
what do u mean by "suck down the gas"? i drive my car exactly like how any insurance company thinks a 19y/o male would :) and i still get around 500 - 550km (340mi)per tank winter and 600 - 650km (400mi)per tank summer, i cant complain
Old 02-21-2011, 11:37 AM   #16
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
nice to know whats inside
its kinda like a DynoMax VT muffler
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-21-2011, 12:41 PM   #17
detroiter
detroiter's Avatar
Sucks down like if you were driving a triton v8 Ford engined vehicle and romping on it. Maybe it doesn't suck gas down that bad but I still get pretty dismal mileage and can't figure it out :(
Old 02-23-2011, 08:18 PM   #18
06silveryaris
Drives: 2006 yaris
if you cut the loop and connect it directly to exit glass pack it will sound nice. This is one I made for a buddy of mine
http://www.youtube.com/watch?v=gIec-3LFs_A
06silveryaris is offline   Reply With Quote
TRD Muffler Keith Tinari Items for Sale by private party 20 01-31-2010 10:47 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 10:08 AM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
FS: OEM STUFF darkmoon87 Items for Sale by private party 2 05-29-2009 05:21 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 07:22 PM
