Old 04-28-2013, 09:45 AM   #19
Diagnostic
Diagnostic's Avatar
Drives: Yaris 5dr 998cc Edition 2012
I have noticed as well that the aftermarket cruise control options for European Yaris are crazy expensive. I believe that the Rostra system, which was the dealer installed cruise control option for the US for 07-08 Yaris, will work on European Yaris, nut I have not had the opportunity to test the theory yet. The Rostra kits were about $250. I actually have one of the kits in my possession, and really need to coordinate doing some experimentation on one of my European trips.
Now I'm really confused or dense; I've been assured the Rostra 250-1836 cruise stalk and the 250-4206 clutch switch will work with my car. I don't see how as its only the switches and a few wires, if the car is not pre-wired and configured theirs nothing smart for the cruise stalk to talk to. Is that right? Or am I both confused and dense? Perhaps this seller wants me to add gullible?
Information provided by: Kartronix- eBay item: 261180202724
Diagnostic is offline   Reply With Quote
Old 04-28-2013, 09:10 PM   #20
The Rostra 250-1836 definitely will not and the 250-4206 is just the clutch switch. It is the same as what I sell (but for much more money). The Rostra kit that I believe will work is the discontinued one that used a smaller stalk that mounted to the opposite side of the steering wheel and had a green LED on the stalk. That kit includes a control box that does the cruise control functionality (which your ECM lacks) and is does so by intercepting and overriding the throttle pedal signals.
Old 05-04-2013, 05:05 AM   #21
Conrod
Drives: 2012 Yaris YR Hatch
I bought a cruse kit off CTScott for my 2012 1.3l Yaris and it worked perfectly and took me 20 minutes to install.
Conrod
Logan City
Queensland
Australia
Conrod is offline   Reply With Quote
Old 05-04-2013, 06:35 AM   #22
Conrod
Logan City
Queensland
Australia
Excellent! So, now we know that both 1.5L and 1.3L Australian 3rd generation Yaris support cruise control.
Old 05-05-2013, 03:35 AM   #23
Diagnostic
Diagnostic's Avatar
Hi Scott. The now obsolete unit you mentioned above; do you have a model number and I'll try and locate one on FleaBay or alternatively perhaps you can provide the kit yourself?
Really, really want to have cruise on my 998cc
Regards
Old 05-05-2013, 08:48 PM   #24
Regards
I can work with you with the kit that I have. We just need to verify a couple of things to confirm my theory before I ship it. I will PM you my email so we can work directly on some photos that I will need.
Old 05-09-2013, 07:14 PM   #25
Kubcat
Drives: 2006 and 2013
Just another confirmation that all worked well on an Australian spec 2013 1.3L automatic.
I did take photos but cant resize them to upload. Many photos on this site anyway so probably not going to add a lot of value by posting mine.
It was extremely easy, the airbag just popped out once the 3 pins were pushed in. I had disconnected the battery before removing the airbag and waited 10 minutes as was advised by a mechanic friend. All in all it took 20 minutes including the 10 minute battery wait and a call to the dealership to get the reprogramming code for the stereo. All plug and play, there was only one slot so couldn't get it wrong. All the functions and cruise control dash indicators work correctly.
The only thing that makes it look not factory is the cover plate that is removed for the cruise control stalk can't be reinstalled as is and there is a gap around it. A photo of a genuine one with a cutout would be nice so I could cut a hole in mine and make it look neater.
Kubcat is offline   Reply With Quote
Old 05-26-2013, 10:24 AM   #26
toyman162
Toyman162
Drives: 2007 Yaris YRX 3-Door
I have shipped cruise control parts to Australia for installation on 3rd generation Yaris with the 1.5L engine. I am not sure about it working on the Australian 1.3L, although it does work for the European 1.33L Yaris.
G'day Scott,
I, too, am from Australia. I have a 2007 1.5 Auto Yaris, and am interested in your cruise control for my car. Do you know if the unit(s) you have sent to Australian owners have worked OK?
If so, how much are the parts shipped here?
Thanks,
John.
toyman162 is offline   Reply With Quote
Old 05-26-2013, 12:14 PM   #27
Originally Posted by toyman162 View Post
G'day Scott,
Thanks,
John.
They have worked for 2012 and newer Yaris, but I am fairly certain that they will not work for 2006-2011 Australian Yaris.
Old 05-29-2013, 12:02 PM   #28
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
...I am not sure if they are still doing so, but in the past for non-factory cruise control installation they always used the Rostra aftermarket system, rather than taking advantage of the ECM's built in functionality.
That's just dumb.. I bought the kit, (from Scott) had it installed in about an hr, and it works beautifully! Dont know why they wouldnt use the built in feature.
CueBall is offline   Reply With Quote
Old 07-08-2013, 06:47 PM   #29
Politronics
Drives: 2009 Yaris Hatchback
HI! I just got a used 2009 Yaris Manual Tranny Hatchback, California car. I have seen some threads about Cal cars no being prepped for the CC. They seem to say that those 2009 and newer are. Can anyone confirm this?
Thanks!
JP
Politronics is offline   Reply With Quote
Old 10-05-2013, 09:53 PM   #30
guitarchaos64
Drives: 2012 toyota yaris le
hi scott,
i just bought a 2012 yaris and would like to install cruise control on it. i live in arizona. can i buy the parts from you?
guitarchaos64 is offline   Reply With Quote
Old 10-05-2013, 10:02 PM   #31
Originally Posted by guitarchaos64 View Post
hi scott,
Yes. PM sent.
Old 01-02-2014, 03:32 PM   #32
jackab
Drives: 2011 Yaris Hatchback
Hi Scott, I have a 2011 Yaris Hatchback, MT, and have been trying to install a Rostra cruise control. I've put in the 250-1836 and the clutch switch. It seems I don't need the ECM hookups and have not put them in. The light comes on at my dash, but the cruise control doesn't work. It sounds like I should just toss it and buy yours. If so, would you want all of this Rostra stuff? Any other tips? Thanks for being out there! Wish I'd found you before messing with Rostra!
jackab is offline   Reply With Quote
Old 01-02-2014, 05:18 PM   #33
If the cruise symbol lights up, then you are good for the ECM connection. If your can't get the "SET" light to come on (and the cruise to actually work), then the clutch switch may not be installed correctly.
The clutch switch needs to be fully depressed when the clutch pedal is not touched in order for cruise to work. If you installed the switch in too far, then it will not actuate when the clutch is at rest and therefore will not allow cruise to work.
The Rostra 250-1836 kit is essentially identical to what I sell, but for a whole lot more money. (The older kits were a custom Rostra product, but the new ones are just the OEM switch, etc.)
Old 01-03-2014, 09:42 PM   #34
jackab
Cool
I checked the clutch, and it looked like the clutch pedal was depressing it enough, but I extended it a bit more anyway. The cruise control still didn't work. I removed the clutch switch wires and went for another drive. Cruise control still didn't work even though the cruise control dash came on. When installing the kit, it seemed too simple an installation for the cruise control to actually work. Does the device send radio signals to the ECM to tell it what to do?
Old 01-03-2014, 09:49 PM   #35
When you say you removed the clutch switch wires, did you unplug the OEM connector that was taped to the harness just above the clutch pedal, or did the Rostra kit include its own wiring for the clutch?
The stalk is a wired connection to the ECM. It is simply four switches and three resistors and the ECM sees the voltage drop across the resistor when one of the switches is pressed. The clutch switch is also a switch input to the ECM, which routes through one of the connectors in the under-hood fuse panel to get there.
Old 01-05-2014, 11:56 PM   #36
jackab
The Rostra instructions said to splice the two wires from the clutch switch to the two wires leading to the A29 connector. The connector was taped up out of the way and was not connected to anything. The CC should work without the clutch switch installed, so I disconnected those wires. Still, the dash CC indicator light comes on and CC doesn't work. I will next take the airbag off and make sure everything is done right there, but it's so simple that even I should be able to get it right.
I installed one of the old style Rostra CC units in my 2010 Yaris, and it works well. It cost a lot more and is more elaborate. The 2011 Yaris belongs to my wife. Her knee is hurting her, and the cruise control helps a lot, so we need to get it going. (You probably didn't need to know all that.)
Thanks for all your time and help.
Bill Foreman
Moab, UT
Mountain Biking Capitol
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
