Old 04-21-2011, 03:19 PM   #1
Jason@SportsCar
SCCA B-Spec
The preliminary rules for SCCA's version of B-Spec have been posted. There are still a few details to be worked out, and some corrections to be made, but is looks like a very inexpensive way to get the Subcompacts out road racing.
For 2011 the cars will all run in Showroom Stock C (SSC), with much faster cars like the Celica GT-S and Acura Integra. This gives the cars a place to play, but it is unlikely any of the B-Spec cars would ever see the podium.
For 2012 the B-Spec cars will still share the track with SSC, but they will be competing only against the other B-Spec cars - sort of a race within the race.
These cars should be very inexpensive to prep, I could see $3k on the low side (MI Autopower cage kit, off the shelf suspension, minimal spares), up to $10k depending on how crazy you want to get (custom cage, custom shocks, piles of wheels and tires). The 98 and 20 cars we worked on are pretty much B-Spec cars at this point - almost like we planned that when we built them.
All of the cars get the same mods, and use 15x7 (min weight 12lbs) wheels with a 205-50-15 DOT R tire, weight will be used to equalize performance. The Yaris is listed at 2250lbs w/driver.
#4607 (CRB) SSC B-Spec rules and specs
Effective upon publication, add a new subsection 9.1.7.E.34 as follows:
“For each of the following cars in SSC, Ford Fiesta 4 door (2010-11), Honda Fit 5 door (2009-2011), Nissan Versa 4-5 door (2010-2011), Mazda2 4 door (2010-2011) and Toyota Yaris 2-4 door (2010-2011), the following apply:
Interiors may be removed, including seats, seat brackets, carpet, carpet padding, OEM seat belts, interior trim and headliners. OEM radio and air conditioner may be removed. Heaters and all duct work must remain, except duct work that goes under seats.
Maximum 2.5 degrees negative chamber on front and rear; MacPherson strut suspension may decamber wheels by the use of eccentric bushings at control arm pivot points, by the use of eccentric bushings at the strut-to-spindle, and/or by use of slotted adjusters at the top of the strut mounting plate. If upper strut slotted plates are used, they shall be located on existing chassis structure, utilizing the OEM bolt holes and may not serve as reinforcement for that structure. On other forms of suspension, camber adjustment may be achieved by the use of shims and/or eccentric bushings.
Ride Height: Minimum ride height is five (5) inches, to be measured without driver at the lowest point of the rocker panels, but not to include welded seams or fasteners.
Suspension: Any OEM or aftermarket non-adjustable shock absorber intended for the specific make, model and year car is permitted. The shock absorber must be installed in the stock mounting location. Remote reservoir shocks are not permitted. Any springs up to a maximum spring rate of 500 pounds may be used. The spring must be installed in the stock location. Threaded shock bodies or adjusters may be used.”
The years are going to be changed for all models that did not have any production changes. This will allow the 2007+ Yaris in.
For 2012 the following cars may be added:
Chevrolet Sonic
Fiat 500
Hyundai Accent
KIA Rio
Scion XD
Scion IQ
VW Polo
2011 NYR SCCA AutoX Schedule NYR Solo Tracking, Racing, Auto-X Forum 0 04-06-2011 01:57 AM
2011 NYR SCCA AutoX Schedule NYR Solo NY / NJ/ CT / PA 0 04-06-2011 01:56 AM
SCCA Classing Update - I WAS WRONG!! ozmdd Tracking, Racing, Auto-X Forum 35 11-09-2009 10:59 AM
Benefits of SCCA rstb88 Tracking, Racing, Auto-X Forum 8 12-01-2008 02:43 PM
