Old 06-28-2011, 12:37 PM   #19
aznofmuff
Drives: yaris08
oh kool thanks!!! sorry scott what is the ignition switch connector?! can u provide a picture of sorts?! thanks so much for being so helpful, i dont even know who you are!!! =D sorry im not very bright thanks a million again!!
aznofmuff is offline   Reply With Quote
Old 06-28-2011, 12:55 PM   #20
It's the one that plugs into the base of the ignition switch. The lower one in this pic with the pink, yellow, grey, black, green, and white wires.
Old 06-29-2011, 10:10 AM   #21
aznofmuff
Drives: yaris08
so what do i do with the multimeter? do i measure the current or the voltage or the resistance?! id so how do i measure the voltagee without the battery and etc... thanks again!
Old 06-29-2011, 10:36 AM   #22
Voltage. Stick the tip of the red lead into the back of the connector, touching the metal of the pin while holding the tip of the black lead to a ground (the metal body of the key switch is fine as the ground).
Measure first with the ignition off and key out and then a second time with the key in and rotated to start. Record the voltage seen on each color wire in both of those modes.
Old 06-29-2011, 12:04 PM   #23
aznofmuff
Drives: yaris08
hey scott, these are the measurements i recorded for the wires.
GREY [ 14.4v off, 14.4v on, 14.4 v start]
YELLOW [ 14.4 off, 14.4 on, 14.4 start]
BLACK [0v off, 0.01 v on, 14.4 v start]
PINK [0v off, 14.3 on, 14.4 start ]
WHITe [0 off, 14.33 on, 0 start]
GREEN [0 v off, 14.43 on, 14.43 start]
thanks!
Old 06-29-2011, 01:47 PM   #24
thanks!
OK - That is all correct.
What I would like you to do next is to swap two relays for me in the under hood fuse panel, to see if the ST relay is bad.
In the diagram below of the fuse box there is the "HTR SUB1" Relay and the *10 Relay (which is the "ST" relay). They are both the same type of relay, so you can safely switch them for a test. Swap them and then try to start it.
Name:  Yaris - Under hood fuse panel.jpg
Old 06-29-2011, 02:26 PM   #25
aznofmuff
Drives: yaris08
hey scott, i just went to look at the fuse book and i dont have the hrb sub 2 relay. just the st relay. i took the st relay to have a look and its got what looks like black ink around the metal connects, is this normal? and is there anything else i can do?! thankssss again for the help
Old 06-29-2011, 02:38 PM   #26
HTR SUB1 is only on Yaris with the supplemental heater, so some don't have it.
The black is normal on the base of the contacts. If you have a 9 volt battery on hand you can touch it to the two contacts on the left side of the picture below. When you do so the relay should click.
Old 06-29-2011, 02:45 PM   #27
aznofmuff
Drives: yaris08
hey scottt i tried putting a 9v battery t the relay and i don't hear anything!!! does this mean that the relay is broken?!!?! thankss again!!!!!!
Old 06-29-2011, 02:49 PM   #28
It likely does. Mine clicks loudly when I do it. Do you have fog lights? If so, you can swap that relay, which is on the side of the under-dash fuse panel.
Old 06-29-2011, 02:49 PM   #29
aznofmuff
Drives: yaris08
ohh nevermind it does click... my bad sorry. so what should i do now?!
Old 06-29-2011, 02:55 PM   #30
Put the relay back in, put your ear right against it, and have someone else turn the key to the start position and see if it clicks while in circuit.
Old 06-29-2011, 05:04 PM   #31
aznofmuff
Drives: yaris08
hey scott yeah it does click when the ignition is turned on. what should i check next/!?!! many thanks yet again!!
Old 06-29-2011, 05:33 PM   #32
Is that one clicking when the key is turned to "START" or is one clicking when it is turned to "ON"?
If that one is definitely the clicking one, then the next thing to try is to pull the relay and using a piece of wire, jump the other two contacts on the relay socket (other two from the ones that you touched the battery to above). Don't fully insert the wire in to the two terminals, but rather just touch it between them,
When you do so, it will make a good spark and theoretically the starter should spin.
Old 06-29-2011, 05:47 PM   #33
aznofmuff
Drives: yaris08
stil nothing... i put the wire across and started the engine but it doesnt wanna do anything... is there anything else u can recommend?! thanks again
Old 06-29-2011, 07:41 PM   #34
With the relay out, measure the voltage between each of those terminals on the relay socket and the negative post of the battery.
Also measure the voltage between the huge wire on the stater and a ground (like the engine block).
Old 07-06-2011, 09:14 AM   #35
lablab
Drives: porsche
If I were you, go the nearest auto shop and let the professional handle it. It might worsen the case if you yourself will touch it,.
Paintless Dent Removal
lablab is offline   Reply With Quote
