Old 06-20-2011, 06:20 PM   #19
Yaris PAVEL94
Okay I got everything to work but that 12 volt purple wire I jumped it from the fuse box and it worked? Where does it go on the inside of the car?
Yaris PAVEL94 is offline   Reply With Quote
Old 06-20-2011, 09:15 PM   #20
The violet one is the feed from the ST relay to the starter. It gets switched indirectly by the black wires on the ignition switch. If the ST relay is not getting energized, it could be the park/neutral switch if you have an auto or the clutch switch if you have an MT.
Old 06-20-2011, 09:23 PM   #21
Yaris PAVEL94
Idk I'm just gonna take it to the dealer tommorow?
Old 06-23-2011, 06:24 PM   #22
Yaris PAVEL94
It was a pink wire in the ignition, by the key
Old 06-23-2011, 10:21 PM   #23
That would be the ignition output wire on the ignition switch. Was the wire damaged?
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
