Old 07-26-2011, 10:02 AM   #19
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Correct. It will have to be evacuated before replacing the part, and then again once the part is on to remove any particulate and moisture.
Alright good. Glad I ordered a replacement then.
Hoping I can get the replacement line in a couple of weeks because August is going to be hot.
devinlamothe is offline   Reply With Quote
Old 07-26-2011, 10:21 AM   #20
devinlamothe
One more thing: I'm looking at the part numbers for the line and I see the following:
88706A TUBE SUB-ASSY, LIQUID, A
88706‑52440 AIR CONDITIONER-MANUAL(B/RESI COMP/VARI) 1 $489.67
88706‑52450 AIR CONDITIONER-DEALER KIT 1 $427.83
What's the difference? I think 88706‑52440 is the correct part but I just want to be sure before I order it.
Old 07-26-2011, 10:28 AM   #21
I saw that as well in the EPC. I am not sure what exactly the difference is. If you PM me your VIN, I can see which ones shows up relative to your VIN.
Old 07-26-2011, 10:46 AM   #22
OK - From your VIN, just the 88706‑52440 part number is highlighted in green, indicating that it is the part used on your car.
Old 07-26-2011, 10:55 AM   #23
devinlamothe
Sweet thanks, that is the one I order then.
Old 07-28-2011, 08:50 AM   #24
devinlamothe
Haha so I brought it back to the dealership for S&G and they said it was going to be $558 for the part and $336 for the labour. Plus when I asked about the dryer unit they said they wouldn't replace it ... NO THANKS!
I ended up getting the parts for just over $200CAD and will do the install myself. Also, Toyota will do the evac/refill for $100 with no charge on the freon since my system is still considered "full."
Old 08-08-2011, 05:50 PM   #25
devinlamothe
Just an update:
Removed the old AC line today and installed the new one. What a B*** to take out and install LOL. The easiest way is to remove the passenger headlamp, take off the front bumper cover, and also there is a meaningless metal support strap on the LOW pressure line that you have to remove before you can get it back on without bending the crap out of the line.
I took my time and it was roughly 1h:30 minutes, FAR from the 3h:30 the dealership quoted me (they said it would take me 5 hours since I wasn't pro).
Can't wait to see the look on their faces tomorrow when I get it recharged.
PS: I hope nothing leaks tomorrow otherwise I will be right embarrassed lol.
PPS: I didn't replace the receiver/dryer on my car since for some reason it is different than what the repair manual states. It says that the top and bottom have a 10mm hex removal point but mine was an entirely self contained unit with no way of removing it unless I replaced the entire condenser. I had someone else look at it and they said most likely it would be fine. So now I have an extra receiver/drier desiccant bag with no use.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/C or Heater Core leaking into passenger floor? The Shape DIY / Maintenance / Service 3 03-23-2015 12:40 AM
Switched Power Behind Passenger Side Glove Boxes? IsLNdbOi DIY / Maintenance / Service 10 07-05-2011 08:25 PM
Replacing Passenger Side Mirror thorcor06 DIY / Maintenance / Service 4 09-03-2010 12:10 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
