Old 10-06-2011, 08:26 PM   #19
skeck
keckbot
skeck's Avatar
Drives: 2007 Blazin' Blue Liftback
Need a relay harness...my kit does not have a relay so i am not getting enough power...guess my question now is do i put the relay harness on the wire that powers the ballast? I am assuming so, as that would make the most sense.
skeck is offline   Reply With Quote
Old 10-06-2011, 08:29 PM   #20
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Yes.. that sounds right to me
Old 10-06-2011, 08:30 PM   #21
skeck
keckbot
skeck's Avatar
Word...thanks
Old 10-06-2011, 10:32 PM   #22
still weird.
they way mine is hooked up, the stock h4 plug splits the high beam power, low beam power and 1 ground into high with a ground and low with a ground.
i don't run a relay harness on mine...just an h1 bulb and a ballast at each low beam projector
Old 10-06-2011, 11:45 PM   #23
skeck
keckbot
skeck's Avatar
Weird?
Ya, mine is different because basically there is one line from each ballast going right to the inside light of the first halo ring then a chord going from the back of that light to the projector bulb in the center of the second halo ring, so it is trying to run 4 HID lights at once versus 2...that is why it is so screwed up. At least that's what I think.
Old 10-07-2011, 12:51 AM   #24
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I run barber's setup and I don'tn need a relay as well.. but I reiterate I think you should take the whole setup out and test with a car battery and multimeter to see what powers what
Old 10-07-2011, 08:35 PM   #25
ya, running 4 hid bulbs on 2 ballasts won't work well
its seems like a really odd setup to me.
Old 10-13-2011, 10:18 PM   #26
skeck
keckbot
skeck's Avatar
HID are fully operational now! Got a Bi-Xenon Relay Harness that arrived today and with a little manipulation all is operating perfectly. If anyone needs help with the Spyder Projectors and installing their HID kit I will be glad to assist. I bought mine on ebay with the HID kit installed. However, they did not come with a relay harness which is a necessity to run them on a yaris. The projector bulbs operate as my headlights and when i flip on the brights the inside lights come on. Both are HID bulbs and it looks fantastic. Unfortunately it is raining outside so i took a nature bath finishing up my install. I willl share pics once the weather clears up. Once it was all said and done i dropped about $280 for both headlights, HID kit and relay harness, not too bad if you ask me. Next I am going to work on retro fitting my old headlights!
