Old 10-05-2011, 09:11 PM   #1
skeck
keckbot
skeck's Avatar
Drives: 2007 Blazin' Blue Liftback
Question New Projector Issues
Okay so I just bought the Spyder Black Projector Headlights with an 8000K HID KIT pre-installed. Got everythign hooked up and the leds, halos work perfectly, and inside headlights both work but when I hit my brights only one of them lights up bright and the other one goes completely dark. Also the projector lights do not fire up.
Has anyone else had this issue?
Any recommendations for how to fix?
I bought the set off of ebay (probably should of known better), so I guess that is what i get. I am waiting to here back from the seller but I was hoping someone else might have some suggestions in case I don't hear back from them. One person i talked to said that I probably wasn;t getting enough power to them and someone else said i should put a fuse on each line from each ballast or else it will fry my wires or fusebox. Anyways, any advice would be much appreciated.
Pictures show the headlights on with projectors not on and the result of turning the brights on, which is that the ppassenger side headlight goes dark while the other one lights up.
Thank you in advance for your suggestions.
skeck is offline   Reply With Quote
