Old 10-17-2011, 07:29 PM   #19
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
My money is on a bad TPS (throttle position sensor), but thats a bit of a shot in the dark with the limited info.
Stove is offline   Reply With Quote
Old 10-18-2011, 12:42 PM   #20
Vinceb
Drives: 2008 5 Speed Sedan
O2 sensors on the exhaust, but they should throw a code.
I agree with Stove, TPS
Ground loop from some added after market components (stereo, Amp, Cap, alarm, remote start).
Have you kept up with maintenance ? oil changes ?
You said you changed the coil and the plugs - so they're properly gaped ? it's not one of those wierd BOSCH 4 tip things is it ? what brand did you put in ?
did you test or change the plug wires ? could be a faulty wire but again, should set a misfire code.
Fuel filter clogged ? - how many miles or KM are on the car ?
Is there a fuel rail pressure regulator on the Yaris ? - I've replaced this on a cavalier before.
loose wires connected to the ECM in the engine, or is the ECM damaged.
You could try disconnecting the battery and leaving the car to sit for a few hours, then reconnect and drive around for a bit, that will reset the computer, and it's worth a try.
Keep us posted.
Vinceb is offline   Reply With Quote
Old 10-19-2011, 02:03 PM   #21
Mr.Tmosh
Drives: 2007 Yaris Sedan 1nz-fe
Keep us posted.
Hello guys, I´m taking the car to the shop this weekend to check everything you´ve said. Grounds, TPS, fuel filter, etc.
The car is 57,xxx KM, the plugs I used are Autolite platinum , I already disconnected the battery to reset the computer, when on "RELEARN" mode I noticed that the revs went up to 3 or a bit higher , and would stay there for about 20 minutes droping and climbing like crazy. Later the car was normal.
Idling the car, revs stay between 1000 and 500 but after 5~7 min the revs drop almost instantly and that´s when the rattling and shaking begins. Even if I press on the gas pedal it struggles to climb the revs.
OK thanks guys, I´ll keep you posted.
Mr.Tmosh is offline   Reply With Quote
Old 10-19-2011, 05:43 PM   #22
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
before anybody says anything, I run Bosch Platinum plugs and I've got no problems.
Sounds liek an electrical sensor issue for sure.. mechanically it's obviously running fine
Old 10-20-2011, 12:13 AM   #23
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Let as know what the culprit is.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
Old 10-20-2011, 12:45 AM   #24
Astroman
Modded Moderator
Astroman's Avatar
Mine was acting weird and shutting off in park (got the slushbox) and it was some wires coming over the intake maniforld were crushed and corroded, and the back of my alternator was crushed (had been hit, body shop missed these things and I discovered them a year later when problems started).
Also check the throttle body... Idle screw might have come loose (even though it should be locked in there with epoxy.
Hope the shop helps you, please keep us posted!
Old 10-20-2011, 03:42 AM   #25
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Question...did you recently get a new battery, do any kind of maintenance, or change any kind of part prior to this happening?
My mum has a 2002 4cyl Camry and the same thing was happening to her car after she got a new battery. The RPM's slowly dropped until the car eventually would stall.
As soon as she put the old battery back in, it was fine.
The solution? Leave the new battery in and drive the hell out of it until the engine's computer realizes it has a new battery.
Black_griffin6 is offline   Reply With Quote
Old 10-20-2011, 10:33 AM   #26
sm2by
sm2by's Avatar
Drives: 08 Yaris Sedan (1.3E Vios)
I had this problem too.
After Cleaning the MAF Sensor and Throttle body didn't fix the rough idle and stalling.
I didn't get any CELs and had the car scanned for trouble codes; none were found.
The techs just swapped my O2 sensor from another sedan and just test drove it for a day, no rough idle or stalling happened.
So I got the O2 sensor replaced under warranty. (Mine was an '08 sedan M/T)
sm2by is offline   Reply With Quote
New 3 Door Yaris Pre Production Photos from the Australian International Motor Show jeikz Third Gen Yaris General Discussion 5 06-27-2011 11:56 PM
