Old 10-31-2011, 06:11 AM   #19
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
ragarding sa ilaw, headlight at tail light lang ang alam kong dapat stock as the foglight is just an accessories, but not that sure kc wala pa namang foglight si storm nung nag pa MVPI ako kaya nung time na un binalik ko ung OEM bulb ng headlight ko at tinanggal ko muna ang relay, I am using a higher wattage white bulb kaya need ng relay.. same procedure ng HID tannggalin lang ang socket ng relay or HID at ibalik ang OEM socket..
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 10-31-2011, 06:53 AM   #20
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
bro @duke anong type ng HID gamit mo? and how much?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 10-31-2011, 07:10 AM   #21
duke_afterdeath
tol hindi ako naka HID pero si tol syntax at ibang kayaris naka HID na.. white bulb lang gamit ko both headlight and foglight with 1000-1200 watts kaya ginamitan ko ng relay
Old 10-31-2011, 07:15 AM   #22
ronan4210
"Fast & Furious"
Drives: 2008 Yaris Sedan - Fleet
so kapag white xenon bulb (not HID) kelangan tanggalin at ikabit ang yellow bulb pag nag pa mvpi? tama ba?
ronan4210 is offline   Reply With Quote
Old 10-31-2011, 07:22 AM   #23
charlieXX
Corporate Slave
charlieXX's Avatar
Ah ok, @duke nightbreakers (osram( ba yan or something higher? wala bang effect sa plastic lense ng headlight?
Old 10-31-2011, 07:29 AM   #24
duke_afterdeath
aiwa
Old 10-31-2011, 09:49 AM   #25
syntax
syntax's Avatar
@ charliexx max wattage ng headlights natin ay 55watts sa normal wiring, sa case ni duke na nasa 1K watts nagbago sya ng wiring at naglagay ng relay, muntik na kasi maging duke_aftersmoked ang handle nya dati eh wehehehehe
Old 10-31-2011, 12:11 PM   #26
duke_afterdeath
nasunog na nga kamo tol
Old 10-31-2011, 01:07 PM   #27
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
@marble, you're right blue tint lang siya not too bright to be HID, san ka nagpapalit niyan or DIY?
yung bulb lng pinalitan ko na blue pero pag umilaw parang flourescent white sya? DIY lng madali nman palitan dudukutin mo lng sa ilalim ng bumper.
marble_bearing is offline   Reply With Quote
Old 10-31-2011, 01:25 PM   #28
duke_afterdeath
tol xenon white bulb lang, medyo mainit nga lang sa ordinary bulb.. medyo faded na ung plastic lense ko, not sure kung dahil sa bulb or dahil na din sa katagalan
Old 10-31-2011, 01:31 PM   #29
duke_afterdeath
tol ilang watts ng bulb gamit mo now?
Old 11-11-2011, 07:45 AM   #30
ronan4210
"Fast & Furious"
bro when you say stock, same color dapat yung bulb, yellow?
how about the park light and turn lights? if i want to change them to other color, kailangan bang ibalik sa stock pag nagpa mvpi? thanks
Old 11-11-2011, 10:54 AM   #31
charlieXX
Corporate Slave
charlieXX's Avatar
@ronan4210 gray area yan pero nung nagpa mvpi ako dati ng Ford ko (my previous car) naka blue park light yun at pumasa naman sa mvpi during the transfer to the new owner.
Old 11-11-2011, 11:08 AM   #32
ronan4210
"Fast & Furious"
SIR CHARLIE.. plan ko kasi sana gawing white or red yung turn light, park light and reverse light. wala kaya probs pag nagpa mvpi? hehe...
Old 11-11-2011, 12:46 PM   #33
charlieXX
Corporate Slave
charlieXX's Avatar
Ay bro sa turn light mahigpit sila, yung smoked lang na nakita ko nun binagsak nila with the other color I am assuming lang po ha not sure na baka hindi lumusot.
On the reverse, alam ko hindi naman na-check yung lights dun
Old 11-12-2011, 10:26 PM   #34
syntax
syntax's Avatar
kamusta na ang foglights mo pre?
Old 11-12-2011, 11:06 PM   #35
charlieXX
Corporate Slave
charlieXX's Avatar
di pa ako nakapunta ng obthany he he he busy busyhan eh
Old 11-13-2011, 01:00 AM   #36
syntax
syntax's Avatar
cge pre' kapag hindi ka na busy busihan, samahan ka namin hehehehe
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan Hershey New YARIS Purchase Forum 9 10-10-2010 01:06 AM
Got my friend into a 2010 Yaris Sedan! Thirty-Nine New YARIS Purchase Forum 8 11-12-2009 03:59 PM
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
