Old 10-28-2011, 04:54 PM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Turning ON Foglights 5dr Sedan 2010 Paano?
Paano po ba it? i found a switch near the handbrake but it does not seem to work?
charlieXX is offline   Reply With Quote
Old 10-28-2011, 05:19 PM   #2
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Probably a open fuse. Paki check mo na lang...under ur dash(driver side).
jonimac is offline   Reply With Quote
Old 10-28-2011, 05:28 PM   #3
charlieXX
Corporate Slave
charlieXX's Avatar
Wala po eh saka whenever I press on the switch near the handbrake the relay underneath the steering wheel engages with a click as well.
Yung sa iyo ba pagka press mo nung switch na yun eh on na agad
Old 10-28-2011, 05:43 PM   #4
jonimac
jonimac's Avatar
OO charlie... actually dalawa ang fuse nyan, isa duon kasama ang ibang fuse para sa mga ilaw, etc. at isa naka hiwalay nandyan din yun sa ilalim, single lang sya with a case, para sa foglights din ito.
Old 10-28-2011, 05:55 PM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Aha thanks for that info, will check it out again....bale normal niya dapat is when the fog lights switch is pressed it turns on immediately right. Walang delay or something, check ko yung fuse.... thank you po
Old 10-28-2011, 05:59 PM   #6
jonimac
jonimac's Avatar
MISMO... okay yan Sir.
Old 10-28-2011, 06:01 PM   #7
jonimac
jonimac's Avatar
My bad sorry... pero dapat PARKLIGHTS ON para gumana and foglights mo, okay?
Old 10-28-2011, 06:08 PM   #8
charlieXX
Corporate Slave
charlieXX's Avatar
Thanks thanks po, will check it out now kasi kahit naka low and hi beam na walang fog lights, normal ba ito na pundihin ang fuse?
Old 10-28-2011, 06:12 PM   #9
jonimac
jonimac's Avatar
When I first got mine, medyo minumulto rin gagana minsan, minsan ayaw. Nang ma-aning ako, check ako kagad to found out maluwag young fuse holder nya(eto yung nakahiwalay), nang palitan ko ito so far hindi na nawawala pa.
Old 10-30-2011, 03:24 PM   #10
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
you might want to check your fog light bulbs maybe it is already busted? the day i got mine it was a one eye jack... replaced the bulb then fog lights on.
marble_bearing is offline   Reply With Quote
Old 10-30-2011, 03:42 PM   #11
charlieXX
Corporate Slave
charlieXX's Avatar
May nakitaan ako na puting puti yung kinabit na foglights, meron kaya nito sa batha?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
Old 10-30-2011, 03:46 PM   #12
marble_bearing
bulb color lang yun sir... like mine blue but flourescent white sya pag umilaw. pag yung nakita mo eh puting puti na sobra liwanag, naka HID yun.
Old 10-30-2011, 04:29 PM   #13
charlieXX
Corporate Slave
charlieXX's Avatar
@marble, you're right blue tint lang siya not too bright to be HID, san ka nagpapalit niyan or DIY?
Old 10-31-2011, 02:47 AM   #14
syntax
syntax's Avatar
@ charlie, go for HID na dahil may foglights ka na, pwede na isabay check kung bakit ayaw mag on ang foglights mo, nasa 200SR ata hindi ko na sure kung magkano ngayon ang HID conversion
Old 10-31-2011, 04:34 AM   #15
charlieXX
Corporate Slave
charlieXX's Avatar
@ syntax problema ko lang sa HID is later on aalisin ko pa ulit for mvpi hindi kasi papasa ayon sa source ko, stock daw dapat at yellow not bright white light unless yung mga luxury cars na galing factory eh ganun na talaga
Old 10-31-2011, 05:18 AM   #16
ronan4210
"Fast & Furious"
Drives: 2008 Yaris Sedan - Fleet
mga bro, tma ba ung sabi ni sir charlie? sir charlie, how about kung naka white or white lead ka sa headlights? hindi ka pa din ba papasa sa mvpi?
ronan4210 is offline   Reply With Quote
Old 10-31-2011, 05:25 AM   #17
syntax
syntax's Avatar
@ charliexx madaling alisin at ilagay ulit ang stock bulbs at ung HID ballast ay parang naka pass thru lang, bale ibabalik lang ung stock bulbs at aalisin ung naka connect sa ballast iddiretso lang ulit sa stock bulbs, madali ito pre'
check natin kina duke, Ej at ricky nakapag MVPI na sila...
Old 10-31-2011, 06:07 AM   #18
charlieXX
Corporate Slave
charlieXX's Avatar
@ syntax wow ganun lang kadali meron ba nito sa obthany anong brand yung maayos? yun bang 200sar na HID eh ok na quality na? wala bang risk na matunaw ang front lens ng head lights natin? as in subok na ba?
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan Hershey New YARIS Purchase Forum 9 10-10-2010 01:06 AM
Got my friend into a 2010 Yaris Sedan! Thirty-Nine New YARIS Purchase Forum 8 11-12-2009 03:59 PM
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
