Old 11-02-2011, 02:48 PM   #19
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Cooooollll!!! see ya Friday mornin
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-02-2011, 03:04 PM   #20
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 11-02-2011, 05:08 PM   #21
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
mga tol, sa akin minsan umaabot ng almost 1500 ang RPM kapag idle, nagugulat nga ako kc akala ko naapakan ko ung gas, madumi na kaya ung sa akin? may nakaranas na ba na habang nakahinto ka sa paakyat na tulay waiting to have a green signal eh parang kabayo ung auto nyo na parang tumatalon talon? naka neutral ako nun at naka hand break, ano kaya yun?
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
xtremist is offline   Reply With Quote
Old 11-02-2011, 05:16 PM   #22
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Originally Posted by duke_afterdeath View Post
carb cleaner found
Al hamdulillah!
jonimac is offline   Reply With Quote
Old 11-02-2011, 05:23 PM   #23
jonimac
jonimac's Avatar
musta bro? ngyari yan minsan kay john umaabot ng 1.5rpm, binugahan lang ulit then tanggal negative sa battery to reset ECU. In ur case tol, dapat siguro palinis mo na yan, taas baba ang menor mo ganyan din ang iba sa amin b4, after cleaning nag normalize na ulit.
Old 11-03-2011, 04:35 AM   #24
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
si iRiSH nman normal pa din and idle (750RPM)...@Jeff si Odi merong carb cleaner kc dati sinamahan ko syang bugaan ung canyang carburator. pwde ntin gawin yan ngayong holiday.
fgorospe76 is offline   Reply With Quote
Old 11-03-2011, 06:00 AM   #25
charlieXX
Corporate Slave
charlieXX's Avatar
Nawala yung taas baba ng idle ko now with the new air cleaner and maintenance cleaning of toyota service in naseem, ganda ng area kitang kita ko habang ginagawa si cutie ko
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
