Old 02-08-2007, 12:31 PM   #19
yarisTOONR82
feed me knowledge!!!
Drives: 2007 Toyota Yaris 3dr HB.
I am looking at buying one and rebuilding the top end. forged titanium rods, forged aluminum pistons, bore it out to 76mm (1.6L), and new head gasket to change the compression to 8.5:1. This way It will be able to handle forced induction reliably and have a little bit more displacement.
yarisTOONR82 is offline   Reply With Quote
Old 02-08-2007, 12:42 PM   #20
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Sounds like an awesome project!!! But I'm not sure if its quite the same engine. I remember hearing something about 2 belts, whereas we have just one...? There are more qualified people than me to answer this.
2006 Red Blitzed RS 5-door
Old 02-08-2007, 09:00 PM   #21
yarisTOONR82
$1000usd for rods, pistons, head gasket, and all hardware.
Old 02-08-2007, 09:01 PM   #22
yarisTOONR82
and $650 for a use engine. (if I can find one that works.)
Old 02-08-2007, 09:03 PM   #23
ChinoCharles
Drives: LB
No power steering belt on the Yaris. Its electric... boogie woogie woogie.
Old 02-08-2007, 09:08 PM   #24
yeah but that should just be a matter of swapping a couple of pulleys
Old 02-08-2007, 09:11 PM   #25
ChinoCharles
Drives: LB
I was just stating the reason for the extra pulley on the Scions... I don't know shit about engine swaps! If you need a steak grilled or a computer built, call me though.
Old 02-08-2007, 10:32 PM   #26
spkrman
Drives: 1
Originally Posted by cdydjded View Post
yaristoon: sorry but you will spend $1000 on the rods alone. I sell JE pistons on eBay & I sell them for $485.00. Even Eagle rods which are the cheapest on the market cost $325.00. I think you meant billet steel rods.
what is your ebay username, pm me :)
Old 02-08-2007, 11:11 PM   #27
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Ya. Woah... thats pretty damn cheap! If you've actually found such a deal, lemme in on it, ok!!
Hahahhahaha... awesome... I'm eating steak while setting up a dual-boot Win98/Win2k POS laptop.
Old 02-08-2007, 11:13 PM   #28
ChinoCharles
Drives: LB
Cow-munching nerds unite!
Old 02-08-2007, 11:35 PM   #29
yarisTOONR82
#17
Toyota 16V DOHC 2000-04
Engine
Code Stock
Bore Includes: Engine Kit #/Price
1NZFE 75mm Complete Gasket Set
Performance MLS Head Gasket
ROSS/Wiseco Forged Pistons
(75, 75.5, 76mm) and
(8.5, 9.0, 9.5, 10.0 comp ratio)
Plasma Moly Rings
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers EKTO41MPX
$969
Call to Order:
(603) 378-0090
Old 02-08-2007, 11:40 PM   #30
yarisTOONR82
there is an upcharge for materials cost on titanium.
Old 02-09-2007, 12:56 AM   #31
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
oooooooooooooooooooooooooooooooooh!!!
Old 02-11-2007, 06:30 PM   #32
FlintArrow
Drives: Flint Mica 2007 Yaris S M.T.
Making a 2zz-ge fit into a Yaris is no easy task, you will need:
1.) An extreme amount of talent and time
or...
2.) A TON of money and a quality shop.
Once you figure out the wiring, engine mounts, CV/lug conversion, and all the firewall modification to make it fit its a matter of making it pass emissions. For those living in a non-testing county this is easy.
If you want to receive a BAR sticker for 49 state emission legality the engine/ecu must have the following:
*Be at least the same year or newer than the chassis (thus limiting your 2zz-ge choices)
*Maintain all factory emission equipment from that powertrain (no hacking cats/stand-alones/etc)
Its true, you could drum up a nasty supercharger system and piggyback computer and tweak it to run clean enough to pass most emission tests (no check engine lights). For the price of a 2zz-ge swap you could either rebuild the engine with titanium components and reinforce the block or just keep throwing in stock 1nz's at $300 + labor per shot.
This way you could also revert it back to stock if you had to sell it w/o trying to explain your Franken-Yaris to a confused buyer.
If your dedicated enough to swap the 2zz I would just cherish every minute with the car and figure a way to register it in the boonies. Its a much easier way for most people to get new license tabs.
PS: The 1zz-fe and the 2zz-ge are equal in difficulty to swap while the only advantage the 1zz has is its price and availability. Performance per buck is nowhere near the 2zz.
FlintArrow is offline   Reply With Quote
Old 02-12-2007, 09:36 PM   #33
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
why go through the trouble to switch engines, the day that there is a sick turbo that comes out for our car your gonna regret waisting all that money bcuz once there is a sick turbo kit out you can build off of that turbo kit and try to get maximum power out of that, if not just sell your car and invest the money you were gonna on a engine swap on a new or used suby or in that class of car..i plan on having the yaris only for about 3-4 years bcuz i want a way faster car bcuz im to young and dont go the flow but soon ill be making bucks to pay off my car and buy a new one
elsteverino889 is offline   Reply With Quote
Old 02-13-2007, 12:39 AM   #34
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Question huh?
why go through the trouble to switch engines...waisting all that money bcuz ... sick turbo kit ... maximum power... bcuz ...bcuz im to young and dont go the flow but soon ill be making bucks to pay off my car and buy a new one
huh?
fu_im_from_texas is offline   Reply With Quote
Old 02-13-2007, 12:47 AM   #35
FlintArrow
Well for the price of any swap you can not only get a "kit" but a full blown custom system. This means your building your car for a purpose not building it per a kit's intent...huge difference.
Sure though, sell the Yaris and get a used WRX. Then you will realize that every gear grinds and half the teeth off your pinion shaft reside on the bottom of the trans. Believe me, an ex suby guy...the only performance Suby with a decent trans to hit the USA is the STI.
There is always someone faster out there. Buy a car you like and be happy with it. Otherwise the one day you sell the Yaris to get a Suby you will run into someone with a fully built Supra, Corvette, 911 GT2, etc and you will feel like its all been a wasted effort.
Not trying to knock the dream...just trying to keep it all in perspective. We have all been there once.
Old 02-13-2007, 11:28 AM   #36
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
K20Z1 FTW.
Nimble is offline   Reply With Quote
Yaris Engine Christopher General Yaris / Vitz Discussion 1 01-17-2007 03:14 AM
engine modify Yaris D-4D uraz Performance Modifications 10 04-30-2006 11:53 AM
