Old 05-09-2012, 12:19 AM   #19
Hershey
Here's a pic side by side where the seals meet a surface . Notice more space between the AC Delco and surface ( block ) . The Toyota less , even with the thin plastic cover .
Old 05-09-2012, 01:35 PM   #20
Hershey
There's about 2,800 miles on this seeping oil filter . Will likely monitor it and let it go until 4.900 miles or so . Then get an U.O.A. since it's a fill of Shell full synthetic 5w-20 . Next oil will be Shell full synthetic 5w-30 ( $3.10 a qt. ) along with the AC Delco oil filter ( $4.00 ).
Old 05-09-2012, 07:39 PM   #21
racerb
I've run only Fram filters on my Toyotas for years with zero issues. They come with dry square shouldered gaskets that you put a light coat of fresh oil on and then tighten to factory specs. I have also run only straight Valvoline synthetic oil changing every 7,500 miles, more frequently when I tow alot. Try the Fram Extra Guard, mostly since it has a rubber coating at the end for easier grip for installation and removal.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-09-2012, 10:17 PM   #22
Hershey
As you can see the seeping is minimal . No oil down the sides or at bottom of filter where it would accumulate over time .
Old 05-09-2012, 10:25 PM   #23
auxmike
auxmike's Avatar
Bit blurry Hershey.
I'm at 50k myself on my '08. My filter was wet on the bottom, but not dripping. I tightened it another 1/8 turn. I gotta check it again... Been using ONLY Thai made OEM the whole way...
Old 05-10-2012, 12:28 AM   #24
Hershey
Originally Posted by auxmike View Post
Bit blurry Hershey.
, sorry not easy to get hands in there for a steady shot . Same here with the YZZF2 up to now . Keep us up to date . Good luck .
Old 05-10-2012, 03:05 AM   #25
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Originally Posted by Hershey View Post
As you can't see the seeping is minimal.
There. I fixed it.
Old 05-10-2012, 11:28 AM   #26
Hershey
Thanks .
Old 06-30-2012, 12:35 AM   #27
Hershey
Did oil change last night at 4.716 miles . Put in Shell synthetic 5w-30 (SN) and installed the AC Delco PF1233 . Went for a 30+ mile drive . Checked the oil filter for any seeping oil after getting back . So far , dry .
Old 06-30-2012, 11:00 PM   #28
Hershey
Over 100 miles and no leak . Knock on block .
Old 10-04-2012, 09:45 PM   #29
craigq
Drives: '07 Yaris, '12 GLI
Bringing this back from the dead. Installed fog lights this afternoon, while under the car I noticed a big blob of oil on the bottom of the filter. Never had this happen before with the Yaris, had to go digging for this thread. It's about 1100 miles since the last oil change, the oil filter is OEM made in Thailand. I did lube the rubber gasket with fresh oil, even though it's pre-lubed from the factory. Will keep an eye on this and report back...
craigq is offline   Reply With Quote
Old 10-04-2012, 10:04 PM   #30
auxmike
auxmike's Avatar
When that happens to me I just tighten it up a hair . I always use one of those cap shaped tools to torque down the OEM Thai filters. They use a very thin o ring gasket vs the aftermarket that uses those wide, thick gaskets that are more forgiving to being on just hand snug..
Old 10-05-2012, 11:40 AM   #31
Hershey
4,300+ miles on the AC Delco and it's clean . Sticking with oil filters with a wider / thicker gasket . Thinking of a HASTINGS , WIX , NAPA Gold , Purolator Pure1 or the AC Delco again .
Old 10-14-2012, 12:10 PM   #32
Hershey
Did a oil change yesterday and installed another AC Delco oil filter and that is leaking worse than the Toyota oil filter. I put fresh oil on the gasket and tightened it the same as the AC Delco oil filter used for the previous oil change. That one didn't leak any oil for 4700 plus miles. Should I tightened it more, clean it and recheck?
Old 10-14-2012, 06:21 PM   #33
Hershey
Tighten oil filter a little bit. Seems fine for now.
Old 11-14-2012, 04:25 PM   #34
craigq
Update to post 29: I did the Yaris' winter oil change today, no further oil detected. Probably from the "oil the seal before installing filter" step in the procedure, this used to happen with my WR250R until the excess oil worked its way out and then it stopped.
HOW TO CHANGE YOUR OIL & FILTER "G" DIY / Maintenance / Service 2 08-14-2011 09:20 PM
My Oil Change Help Me, Please! JetfireK General Yaris / Vitz Discussion 6 01-09-2011 10:25 PM
Oil filter and oil jstantherprsn DIY / Maintenance / Service 11 10-19-2010 08:55 AM
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
